Did it run an 8?
#3042122
05/13/22 11:28 PM
05/13/22 11:28 PM
Posts: 9,856 MI, usa
dvw
MI, usa
Today was the day. Very nervous about everything after the big Kaboom. My son Scott (Dizuster) came with me and helped tune. Well it went down the track. Didn't spit any parts out. Weather was hot for May in central Michigan, 88-90. Baro was 28.9x all day. Correction factor 8-9%. Started off with a spinning 9.179@146.12. 86 jets, 34 degrees timing. Not really what we looking for. newly revalved shocks up front. Car had zero rotation. Left flat as a pancake. The front rebound was actually looser than Afco had suggested. Checking the rear shocks, I had the rebound on the right rear full tight. Straightened that out for a near duplicate run #2 9.174@145.04. Pull the timing back from 34 to 32 for run #3. Well that didn't work. Clean cut no heat on the strap and lean popping on the top end, 9.209@143.5. Video showed the housing bouncing back up into the car as well. Upped the rear compression 2 clicks, up 4 jet sizes to 90's and bumped the timing to 35,. Lots of changes at once but we've got to fix it, 9.149@147.42. Better loosened the front rebound 5 clicks, 9.091@147.95. Loosened the fronts another 5 clicks and bumped the timing to 36. Started the car and a LOUD knocking. Scott is waving at me not to worry. My buddy yells at him "put the spark plug back in". Heart attack moment. Got that straightened out as he was looking for the timing mark on the strap. When up for the pass. It pulled the wheels for the first pass today, not much but we're getting closer. D/A 3778, First 60 ft today in the 1.20's 1.293 / 5.742@120.53 / 9.028@149.10. Ready for one last pass the battery charger failed. So all in all pretty good. We can make it hook. Didn't get aggressive enough loosening the front early. in the day. But after last years wheelie oil pan smashing fiasco caution was the word. We also talked about the cam being backed up may have some bearing on the 60 ft. I have some larger jets coming. We will continue to loosen the front. The 8 is coming. Doug
Re: Did it run an 8?
[Re: dvw]
#3042129
05/13/22 11:48 PM
05/13/22 11:48 PM
Posts: 4,688 On the parachute mount
n20mstr
Congrats on a great outing after the rebuild Impressive for sure , looks like the cam timing helped 8โs are right there
....BAD A$$ STREET CAR.....
[Re: dvw]
#3042141
05/14/22 12:34 AM
05/14/22 12:34 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Today was the day. Very nervous about everything after the big Kaboom. My son Scott (Dizuster) came with me and helped tune. Well it went down the track. Didn't spit any parts out. Weather was hot for May in central Michigan, 88-90. Baro was 28.9x all day. Correction factor 8-9%. Started off with a spinning 9.179@146.12. 86 jets, 34 degrees timing. Not really what we looking for. newly revalved shocks up front. Car had zero rotation. Left flat as a pancake. The front rebound was actually looser than Afco had suggested. Checking the rear shocks, I had the rebound on the right rear full tight. Straightened that out for a near duplicate run #2 9.174@145.04. Pull the timing back from 34 to 32 for run #3. Well that didn't work. Clean cut no heat on the strap and lean popping on the top end, 9.209@143.5. Video showed the housing bouncing back up into the car as well. Upped the rear compression 2 clicks, up 4 jet sizes to 90's and bumped the timing to 35,. Lots of changes at once but we've got to fix it, 9.149@147.42. Better loosened the front rebound 5 clicks, 9.091@147.95. Loosened the fronts another 5 clicks and bumped the timing to 36. Started the car and a LOUD knocking. Scott is waving at me not to worry. My buddy yells at him "put the spark plug back in". Heart attack moment. Got that straightened out as he was looking for the timing mark on the strap. When up for the pass. It pulled the wheels for the first pass today, not much but we're getting closer. D/A 3778, First 60 ft today in the 1.20's 1.293 / 5.742@120.53 / 9.028@149.10. Ready for one last pass the battery charger failed. So all in all pretty good. We can make it hook. Didn't get aggressive enough loosening the front early. in the day. But after last years wheelie oil pan smashing fiasco caution was the word. We also talked about the cam being backed up may have some bearing on the 60 ft. I have some larger jets coming. We will continue to loosen the front. The 8 is coming. Doug Big congrats, Doug. With 3800 da going 9.02, and more tuning to do, it shows your hard work paid off๐
[Re: gregsdart]
#3042144
05/14/22 12:41 AM
05/14/22 12:41 AM
Posts: 170 Sticky South
Rodenteliminator
Sticky South
I would say that you just needed better air, the rest of it is there, looks good. Doug
Sorry honey I spent the rent
[Re: slantzilla]
#3042152
05/14/22 02:49 AM
05/14/22 02:49 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
Great result for what iwould be terrible da here . Fall or earlier cooler day will be your friend
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#3042168
05/14/22 07:25 AM
05/14/22 07:25 AM
Posts: 4,687 Wichita
GY3
Wichita
You made progress, though, so that's something to feel good about!
[Re: dvw]
#3042191
05/14/22 08:50 AM
05/14/22 08:50 AM
Posts: 3,203 Md.
carnut68
Md.
Today was the day. Very nervous about everything after the big Kaboom. My son Scott (Dizuster) came with me and helped tune. Well it went down the track. Didn't spit any parts out. Weather was hot for May in central Michigan, 88-90. Baro was 28.9x all day. Correction factor 8-9%. Started off with a spinning 9.179@146.12. 86 jets, 34 degrees timing. Not really what we looking for. newly revalved shocks up front. Car had zero rotation. Left flat as a pancake. The front rebound was actually looser than Afco had suggested. Checking the rear shocks, I had the rebound on the right rear full tight. Straightened that out for a near duplicate run #2 9.174@145.04. Pull the timing back from 34 to 32 for run #3. Well that didn't work. Clean cut no heat on the strap and lean popping on the top end, 9.209@143.5. Video showed the housing bouncing back up into the car as well. Upped the rear compression 2 clicks, up 4 jet sizes to 90's and bumped the timing to 35,. Lots of changes at once but we've got to fix it, 9.149@147.42. Better loosened the front rebound 5 clicks, 9.091@147.95. Loosened the fronts another 5 clicks and bumped the timing to 36. Started the car and a LOUD knocking. Scott is waving at me not to worry. My buddy yells at him "put the spark plug back in". Heart attack moment. Got that straightened out as he was looking for the timing mark on the strap. When up for the pass. It pulled the wheels for the first pass today, not much but we're getting closer. D/A 3778, First 60 ft today in the 1.20's 1.293 / 5.742@120.53 / 9.028@149.10. Ready for one last pass the battery charger failed. So all in all pretty good. We can make it hook. Didn't get aggressive enough loosening the front early. in the day. But after last years wheelie oil pan smashing fiasco caution was the word. We also talked about the cam being backed up may have some bearing on the 60 ft. I have some larger jets coming. We will continue to loosen the front. The 8 is coming. Doug That car is sweet! Glad you have it back in action.
America First!
[Re: tboomer]
#3042194
05/14/22 09:00 AM
05/14/22 09:00 AM
gregsdart
You made progress, though, so that's something to feel good about! X2! I am more confidant that Dougs' ride is now a bonified 8 second ride. With tweaking, it will be an 8.9x ride on all but the very worst days, (+4500 DA) and 8.7x on the best of days. This is truly great performance coming out of 440-1 heads, as well as the induction Doug runs.
[Re: slantzilla]
#3042325
05/14/22 05:19 PM
05/14/22 05:19 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Bravo! Nice job and accomplishment. Beautiful car that hauls ass!
"Any fool can know. The point is to understand"
- A. Einstein
[Re: HardcoreB]
#3042707
05/16/22 08:51 AM
05/16/22 08:51 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Awesome! A lil better air and you should be in the 8s easily!
[Re: an8sec70cuda]
#3042710
05/16/22 08:57 AM
05/16/22 08:57 AM
Posts: 10,038 MN
JERICOGTX
MN
Nice work Doug. What was the best mph previously?
Jeff
69 GTX
68 Road Runner
[Re: dvw]
#3042771
05/16/22 11:50 AM
05/16/22 11:50 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Does it have a chute already? IIRC, that's mandatory for cars going 150.00 + in the 1/4...
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: dvw]
#3042782
05/16/22 12:19 PM
05/16/22 12:19 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
Thanks for the post, I think most of us have left a spark plug out at least once! (some more than once). Saw the video on Fakebook too, looks great as ever. Sure seems like it's going to run 8s real soon.
Rich H.
Esse Quam Videri
[Re: dvw]
#3042790
05/16/22 12:39 PM
05/16/22 12:39 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I change the tranny fluid last year from some magic trick fluid to straight Valvoline Type F ATF non synthetic and picked up .02 in the 60 Ft times 1.25 to 1.23 if you don't test, even if your not planning on that switch being a test, your not going to learn anything, correct
