Did it run an 8? #3042122
05/13/22 11:28 PM
05/13/22 11:28 PM
MI, usa
dvw Online content OP
dvw  Online Content OP
MI, usa
Today was the day. Very nervous about everything after the big Kaboom. My son Scott (Dizuster) came with me and helped tune. Well it went down the track. Didn't spit any parts out. Weather was hot for May in central Michigan, 88-90. Baro was 28.9x all day. Correction factor 8-9%. Started off with a spinning 9.179@146.12. 86 jets, 34 degrees timing. Not really what we looking for. newly revalved shocks up front. Car had zero rotation. Left flat as a pancake. The front rebound was actually looser than Afco had suggested. Checking the rear shocks, I had the rebound on the right rear full tight. Straightened that out for a near duplicate run #2 9.174@145.04. Pull the timing back from 34 to 32 for run #3. Well that didn't work. Clean cut no heat on the strap and lean popping on the top end, 9.209@143.5. Video showed the housing bouncing back up into the car as well. Upped the rear compression 2 clicks, up 4 jet sizes to 90's and bumped the timing to 35,. Lots of changes at once but we've got to fix it, 9.149@147.42. Better loosened the front rebound 5 clicks, 9.091@147.95. Loosened the fronts another 5 clicks and bumped the timing to 36. Started the car and a LOUD knocking. Scott is waving at me not to worry. My buddy yells at him "put the spark plug back in". Heart attack moment. Got that straightened out as he was looking for the timing mark on the strap. When up for the pass. It pulled the wheels for the first pass today, not much but we're getting closer. D/A 3778, First 60 ft today in the 1.20's 1.293 / 5.742@120.53 / 9.028@149.10. Ready for one last pass the battery charger failed. So all in all pretty good. We can make it hook. Didn't get aggressive enough loosening the front early. in the day. But after last years wheelie oil pan smashing fiasco caution was the word. We also talked about the cam being backed up may have some bearing on the 60 ft. I have some larger jets coming. We will continue to loosen the front. The 8 is coming.
Doug
Re: Did it run an 8? [Re: dvw] #3042129
05/13/22 11:48 PM
05/13/22 11:48 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Congrats on a great outing after the rebuild
Impressive for sure , looks like the cam timing helped
8โ€™s are right there up
....BAD A$$ STREET CAR.....
Re: Did it run an 8? [Re: dvw] #3042141
05/14/22 12:34 AM
05/14/22 12:34 AM
gregsdart Offline
gregsdart  Offline
Doug
Big congrats, Doug. With 3800 da going 9.02, and more tuning to do, it shows your hard work paid off๐Ÿ‘
Re: Did it run an 8? [Re: gregsdart] #3042144
05/14/22 12:41 AM
05/14/22 12:41 AM
Sticky South
Rodenteliminator Offline
Sticky South
I would say that you just needed better air, the rest of it is there, looks good. Doug
Sorry honey I spent the rent
Re: Did it run an 8? [Re: Rodenteliminator] #3042146
05/14/22 12:48 AM
05/14/22 12:48 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Congratulations Doug! The hard work is paying off.
Re: Did it run an 8? [Re: slantzilla] #3042152
05/14/22 02:49 AM
05/14/22 02:49 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Great result for what iwould be terrible da here .
Fall or earlier cooler day will be your friend
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Did it run an 8? [Re: tex013] #3042168
05/14/22 07:25 AM
05/14/22 07:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
You made progress, though, so that's something to feel good about!
'63 Dodge 330
11.19 @ 121 mph
Re: Did it run an 8? [Re: GY3] #3042174
05/14/22 07:50 AM
05/14/22 07:50 AM
tboomer Offline
tboomer  Offline
X2!
Re: Did it run an 8? [Re: dvw] #3042191
05/14/22 08:50 AM
05/14/22 08:50 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Doug
That car is sweet! Glad you have it back in action.
America First!
Re: Did it run an 8? [Re: tboomer] #3042194
05/14/22 09:00 AM
05/14/22 09:00 AM
gregsdart Offline
gregsdart  Offline
X2!
I am more confidant that Dougs' ride is now a bonified 8 second ride. With tweaking, it will be an 8.9x ride on all but the very worst days, (+4500 DA) and 8.7x on the best of days. This is truly great performance coming out of 440-1 heads, as well as the induction Doug runs.
Re: Did it run an 8? [Re: gregsdart] #3042292
05/14/22 03:30 PM
05/14/22 03:30 PM
moparx Offline
moparx  Offline
my favorite car here will get 8's next time out for sure. i said so ! boogie
beer
Re: Did it run an 8? [Re: slantzilla] #3042325
05/14/22 05:19 PM
05/14/22 05:19 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Bravo! Nice job and accomplishment. Beautiful car that hauls ass!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Did it run an 8? [Re: dvw] #3042335
05/14/22 06:07 PM
05/14/22 06:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
149!! I HATE you!! laugh2 that got โ€œ8โ€ wrote all over it! Nice passes!
Re: Did it run an 8? [Re: J_BODY] #3042466
05/15/22 10:44 AM
05/15/22 10:44 AM
Shelby Twp. Mi
HardcoreB Online content
HardcoreB  Online Content
Shelby Twp. Mi
New (old) combo is flying, congrats! Dialing back to 9.0's will feel good.
Re: Did it run an 8? [Re: HardcoreB] #3042707
05/16/22 08:51 AM
05/16/22 08:51 AM
an8sec70cuda Offline
Awesome! A lil better air and you should be in the 8s easily!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Did it run an 8? [Re: an8sec70cuda] #3042710
05/16/22 08:57 AM
05/16/22 08:57 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Nice work Doug. What was the best mph previously?
Jeff
69 GTX 68 Road Runner
Re: Did it run an 8? [Re: JERICOGTX] #3042769
05/16/22 11:46 AM
05/16/22 11:46 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
Great update. Congrats!
Re: Did it run an 8? [Re: dvw] #3042771
05/16/22 11:50 AM
05/16/22 11:50 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Does it have a chute already? IIRC, that's mandatory for cars going 150.00 + in the 1/4...
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Did it run an 8? [Re: dvw] #3042782
05/16/22 12:19 PM
05/16/22 12:19 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thanks for the post, I think most of us have left a spark plug out at least once! (some more than once).
Saw the video on Fakebook too, looks great as ever. Sure seems like it's going to run 8s real soon.
Rich H.
Esse Quam Videri
Re: Did it run an 8? [Re: dvw] #3042790
05/16/22 12:39 PM
05/16/22 12:39 PM
I change the tranny fluid last year from some magic trick fluid to straight Valvoline Type F ATF non synthetic and picked up .02 in the 60 Ft times shock 1.25 to 1.23 boogie
if you don't test, even if your not planning on that switch being a test, your not going to learn anything, correct work
