518 line pressure #3040670
05/07/22 08:43 PM
05/07/22 08:43 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
line pressure,(518 46rh)
i have a direct gauge on my car to check LP, it had 70psi in 1-2-3 gears at idle. i manually activated the kick down lever, it had 110 at idle,
i have a 3800lbs car with over 700pound feet of torque.
i want to ad LP. when i backed the adjuster screw out 2 full turns the gauge starts to flutter 70-90 1-2-3 and 110-120 with KD activated, all at idle.
what can i do to add psi but stop the fluttering.…
trans-go kit in VB
also, no psi in p-r -n at idle
Re: 518 line pressure [Re: mcat4321] #3040766
05/08/22 01:07 PM
05/08/22 01:07 PM
moparx Offline
moparx  Offline
here is a bump so members Transman or Kunkle can possibly see this and reply.
beer
Re: 518 line pressure [Re: mcat4321] #3040784
05/08/22 03:22 PM
05/08/22 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Your line pressure is a little higher than stock which is predictable with the Transgo kit. To get more pressure you'll need a regulator spring with a higher value
Re: 518 line pressure [Re: John_Kunkel] #3040786
05/08/22 03:24 PM
05/08/22 03:24 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
My Tgo kit for 518 came with a stronger spring
Re: 518 line pressure [Re: CSK] #3040791
05/08/22 04:59 PM
05/08/22 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, but that spring is designed for a specific pressure range...pretty much what the OP has.
Re: 518 line pressure [Re: John_Kunkel] #3040797
05/08/22 05:33 PM
05/08/22 05:33 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
10-4
Thats what I have & my junker makes 700ish TQ
Re: 518 line pressure [Re: mcat4321] #3040826
05/08/22 07:59 PM
05/08/22 07:59 PM
A727Tflite Offline
A727Tflite  Offline
trans-go kit in VB
What engine speed did you experience the flutter ?
Record that speed, the raise the engine speed higher with the lever back and report back - still fluttering? Less/more?
Re: 518 line pressure [Re: mcat4321] #3040900
05/09/22 07:02 AM
05/09/22 07:02 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
most likely the flutter at idle is that you are maxing out the output of your pump. the flutter is the pressure relief valve bouncing as the pump struggles at max demand. Making sure all the clearances in the pump are good and tight, is the only thing I know that will help. But you may be asking more than your pump will deliver, as long as it has enough pressure at speed it should hold up just fine. Check the pressure in reverse, that is normally the max pressure the pump can build. Look at the stock specs you will see reverse is almost twice what the forward gears are.
Re: 518 line pressure [Re: jwb123] #3040960
05/09/22 12:58 PM
05/09/22 12:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The pump is capable of putting out over 300 psi at idle so it's not a lack of pump capacity. The regulator is the key.
Some full-race VB's regulators are set up to over 200 psi line pressure, not sure how it's done.
Re: 518 line pressure [Re: John_Kunkel] #3041039
05/09/22 07:08 PM
05/09/22 07:08 PM
Mo.
racerx Offline
racerx  Offline
Mo.
John is you talking about the stock pumps for the 727/518?
Op consider this a bump i'v been keeping scope on this thread i'm also curios about line pressure too.
Re: 518 line pressure [Re: racerx] #3041204
05/10/22 01:22 PM
05/10/22 01:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, stock pump. The pump is capable of much higher pressure than the regulator allows.
Re: 518 line pressure [Re: John_Kunkel] #3041385
05/11/22 07:11 AM
05/11/22 07:11 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks John up...i imagine that can cause stress on the lugs on the pump causing them to break due to increase pressure work
