Re: 518 line pressure
[Re: mcat4321]
#3040784
05/08/22 03:22 PM
05/08/22 03:22 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Your line pressure is a little higher than stock which is predictable with the Transgo kit. To get more pressure you'll need a regulator spring with a higher value
[Re: John_Kunkel]
#3040786
05/08/22 03:24 PM
05/08/22 03:24 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
Your line pressure is a little higher than stock which is predictable with the Transgo kit. To get more pressure you'll need a regulator spring with a higher value My Tgo kit for 518 came with a stronger spring
[Re: CSK]
#3040791
05/08/22 04:59 PM
05/08/22 04:59 PM
John_Kunkel
Rio Linda, CA
Yes, but that spring is designed for a specific pressure range...pretty much what the OP has.
[Re: John_Kunkel]
#3040797
05/08/22 05:33 PM
05/08/22 05:33 PM
CSK
Pattison Texas
10-4 Thats what I have & my junker makes 700ish TQ
[Re: mcat4321]
#3040826
05/08/22 07:59 PM
05/08/22 07:59 PM
Posts: 3,087 Michigan
A727Tflite
line pressure,(518 46rh) i have a direct gauge on my car to check LP, it had 70psi in 1-2-3 gears at idle. i manually activated the kick down lever, it had 110 at idle, i have a 3800lbs car with over 700pound feet of torque. i want to ad LP. when i backed the adjuster screw out 2 full turns the gauge starts to flutter 70-90 1-2-3 and 110-120 with KD activated, all at idle. what can i do to add psi but stop the fluttering.… trans-go kit in VB also, no psi in p-r -n at idle What engine speed did you experience the flutter ? Record that speed, the raise the engine speed higher with the lever back and report back - still fluttering? Less/more?
[Re: jwb123]
#3040960
05/09/22 12:58 PM
05/09/22 12:58 PM
John_Kunkel
Rio Linda, CA
The pump is capable of putting out over 300 psi at idle so it's not a lack of pump capacity. The regulator is the key.
Some full-race VB's regulators are set up to over 200 psi line pressure, not sure how it's done.
[Re: John_Kunkel]
#3041039
05/09/22 07:08 PM
05/09/22 07:08 PM
Posts: 4,072 Mo.
racerx
Mo.
Some full-race VB's regulators are set up to over 200 psi line pressure, not sure how it's done. John is you talking about the stock pumps for the 727/518? Op consider this a i'v been keeping on this thread i'm also curios about line pressure too.
[Re: racerx]
#3041204
05/10/22 01:22 PM
05/10/22 01:22 PM
John_Kunkel
Rio Linda, CA
Yes, stock pump. The pump is capable of much higher pressure than the regulator allows.
