Rear mounted transmission cooler and rad overflow??
#3040129
05/05/22 10:24 PM
05/05/22 10:24 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
It was suggested that i mount my radiator over flow and transmission cooler at the rear behind the tires Does anyone have pics of their setup?
This is street / strip setup
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Rear mounted transmission cooler and rad overflow??
[Re: Kam*Kuda]
#3040293
05/06/22 12:14 PM
05/06/22 12:14 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
How much does each one weigh? I wouldn't worry or even think about doing that on a street and strip car, use your skills for better results ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Cab_Burge]
#3040304
05/06/22 12:27 PM
05/06/22 12:27 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I like to mount the trans cooler under the car and close to the transmission to keep the lines short. I've even mounted them on the crossmember so they come down with the trans when removing.
Mounting in the back somewhere works too. Up under the floor in the rear seat area. Never gone all the way to the trunk. Any place is preferable to all the stuff and lines up on the radiator.
Not sure why it's fashionable to put the overflow in the trunk. Not that much weight and you have a 18' long hose to run and secure.
[Re: AndyF]
#3040507
05/07/22 07:35 AM
05/07/22 07:35 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I don't have the trans cooler fitted at the rear but the coolant overflow can is. I re-located it there after a buddy had a close call with the wall when his head gasket blew. The gasket failed just enough to pressurise the water system and dump the contents out through his catch can. At the time it was fitted at the front. Needless to say a lot have followed suit. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3040510
05/07/22 08:11 AM
05/07/22 08:11 AM
Posts: 9,883 MI, usa
dvw
MI, usa
Here's mine. Mounted under the drivers seat inside the frame rail in case failure the fluid isn't in the tire path. No fan fluid has never seen 200 degrees. Doug
[Re: moparx]
#3040555
05/07/22 12:44 PM
05/07/22 12:44 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
I always mount my trans coolers in the back. Working on the truck now and it is just behind the rear end between the framerails.
[Re: dvw]
#3040561
05/07/22 01:00 PM
05/07/22 01:00 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Here's mine. Mounted under the drivers seat inside the frame rail in case failure the fluid isn't in the tire path. No fan fluid has never seen 200 degrees. Doug Just how I've done it numerous times.
[Re: moparx]
#3040562
05/07/22 01:01 PM
05/07/22 01:01 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
for those that run a fan on their cooler, is it a pusher or puller style unit ? or doesn't it make a difference ? Any fan will work much better as a puller.
[Re: Tig]
#3040846
05/08/22 09:26 PM
05/08/22 09:26 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
I don't have the trans cooler fitted at the rear but the coolant overflow can is. I re-located it there after a buddy had a close call with the wall when his head gasket blew. The gasket failed just enough to pressurise the water system and dump the contents out through his catch can. At the time it was fitted at the front. Needless to say a lot have followed suit. THAT IS EXACTLY why I was asking. This happened to a friend and the fluid under the tires put the car int the wall. I would expect the Trans cooler to also be behind the tire! Would that not be the safest in case of issues?
[Re: Kam*Kuda]
#3040899
05/09/22 07:00 AM
05/09/22 07:00 AM
Tig
A shed in England
I don't have the trans cooler fitted at the rear but the coolant overflow can is. I re-located it there after a buddy had a close call with the wall when his head gasket blew. The gasket failed just enough to pressurise the water system and dump the contents out through his catch can. At the time it was fitted at the front. Needless to say a lot have followed suit. THAT IS EXACTLY why I was asking. This happened to a friend and the fluid under the tires put the car int the wall. I would expect the Trans cooler to also be behind the tire! Would that not be the safest in case of issues? Have to agree it would be the best place for it. It would also need a fan since air flow is limited there. Our trans cooler is in the usual place in front of the radiator for best air flow. It's connected with AN fitting's and hose to minimize the risk and I'm confidant it will be OK. But ultimately, the rear (with a fan) will be the ideal place.
[Re: Tig]
#3040966
05/09/22 01:05 PM
05/09/22 01:05 PM
Cab_Burge
[Re: Cab_Burge]
#3041161
05/10/22 10:25 AM
05/10/22 10:25 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
That's a great comment I often think the bigger the better Maybe not the case here
[Re: Kam*Kuda]
#3041177
05/10/22 11:38 AM
05/10/22 11:38 AM
Tig
A shed in England
It depends where you monitor the temp. If you set your gauge to read the temp in the O/P line to the trans cooler I see 240 - 260 degrees during a pass. The pan is around 170. The line temp plummets when you lift off the gas. Pretty scary at first but after 10+ years with no problems you get confidant it must be normal ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: Tig]
#3041219
05/10/22 02:02 PM
05/10/22 02:02 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
It depends where you monitor the temp. If you set your gauge to read the temp in the O/P line to the trans cooler I see 240 - 260 degrees during a pass. The pan is around 170. The line temp plummets when you lift off the gas. Pretty scary at first but after 10+ years with no problems you get confidant it must be normal Yeah I have done that before, a little panic inducing at first! 8" 4500 converter in front of the rad, no fan. The highest temp I have seen is like 180-190 and that was after hours of crawling in rush hour traffic.
68 Barracuda Formula S 340
