Remflex Fan Now
#3039618
05/04/22 10:02 AM
05/04/22 10:02 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Was having issues with warped head pipe flange tabs and getting to seal to manifolds using standard gaskets with or without sealing rings. Tried these and worked perfectly. Will see if they hold up or blow out over time. Remflex 6006They do certainly squish down.
Re: Remflex Fan Now
[Re: njmopar]
#3039680
05/04/22 01:34 PM
05/04/22 01:34 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
I’m considering ordering a set for stock manifolds. I think mine are leaking at the head pipes. Never unused them before.
I want my fair share
Re: Remflex Fan Now
[Re: mopars4ever]
#3039902
05/05/22 10:02 AM
05/05/22 10:02 AM
njmopar
Clinton, NJ
They work well but I only got a one time use out of them. They are pretty thick and they stuck to the headers when I removed them to pull the headers back off. I can see that happening. Hopefully for me, will be on there a LONG time. I do plan to keep a spare set on my shelf, in particular since you cant get them everywhere.
Re: Remflex Fan Now
[Re: njmopar]
#3039959
05/05/22 01:17 PM
05/05/22 01:17 PM
Posts: 3,384 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
They work well but I only got a one time use out of them. They are pretty thick and they stuck to the headers when I removed them to pull the headers back off. I can see that happening. Hopefully for me, will be on there a LONG time. I do plan to keep a spare set on my shelf, in particular since you cant get them everywhere. I had the hardest time getting my warped cheapo-headers to seal up. Once I put Reflex gaskets on no leaks. They work. As mentioned the only downside is they are somewhat fragile. Be careful installing them, and once they are on don't try to take them off.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
