K member weight loss? #3039511
05/03/22 09:12 PM
05/03/22 09:12 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anyone know how much weight loss there is going from stock k member to a alterktion k member on a 64 b body? Thanks
Re: K member weight loss? [Re: bobs69] #3039530
05/03/22 10:22 PM
05/03/22 10:22 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
stock v8 k frame is 37lbs
JAKES AUTOMOTIVE
Re: K member weight loss? [Re: JAKE68] #3039533
05/03/22 10:37 PM
05/03/22 10:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You could just as well cut the stock one. There's not 10 lbs difference in the end. Way less money and works well.
Doug
Re: K member weight loss? [Re: dvw] #3039592
05/04/22 08:22 AM
05/04/22 08:22 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
You might be able to search it but the big weight loss on the aftermarket K frames is going to lightweight brakes and getting rid of the stock steering box. The frames themselves are fairly close. Obviously, there are other advantages with header fitment etc.
Re: K member weight loss? [Re: JAKE68] #3039676
05/04/22 01:10 PM
05/04/22 01:10 PM
My stock 1965 dart six-cylinder K frame weighs 23 Lbs. boogie
I'm going to cut the stock mounts off and use a front engine aluminum plate attached to some angle iron I will weld on the sub frame once I get the motor located were I want itwrench
Re: K member weight loss? [Re: dvw] #3039709
05/04/22 02:58 PM
05/04/22 02:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Doug
I’m amazed everytime I see this. Beautiful job.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: K member weight loss? [Re: dvw] #3039863
05/05/22 02:19 AM
05/05/22 02:19 AM
Doug
i think I would be shortening the three bolts holding the steering box to the K frame, unless they are Titanium or aluminum devil
Re: K member weight loss? [Re: Cab_Burge] #3039865
05/05/22 03:32 AM
05/05/22 03:32 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Doug
Center drill them, too. drive
Re: K member weight loss? [Re: bobby66] #3039918
05/05/22 10:51 AM
05/05/22 10:51 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When I bought my AJE he claimed "up to" 120# weight loss. The fine print was that included getting rid of factory power steering and power disc brakes. If you already had manual steering almost all the weight was the brakes.
