Re: K member weight loss?
[Re: bobs69]
#3039530
05/03/22 10:22 PM
05/03/22 10:22 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
stock v8 k frame is 37lbs
JAKES AUTOMOTIVE
[Re: JAKE68]
#3039533
05/03/22 10:37 PM
05/03/22 10:37 PM
Posts: 9,813 MI, usa
dvw
MI, usa
You could just as well cut the stock one. There's not 10 lbs difference in the end. Way less money and works well. Doug
[Re: dvw]
#3039709
05/04/22 02:58 PM
05/04/22 02:58 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You could just as well cut the stock one. There's not 10 lbs difference in the end. Way less money and works well. Doug I’m amazed everytime I see this. Beautiful job.
[Re: dvw]
#3039863
05/05/22 02:19 AM
05/05/22 02:19 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
You could just as well cut the stock one. There's not 10 lbs difference in the end. Way less money and works well. Doug i think I would be shortening the three bolts holding the steering box to the K frame, unless they are Titanium or aluminum
[Re: bobby66]
#3039918
05/05/22 10:51 AM
05/05/22 10:51 AM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
When I bought my AJE he claimed "up to" 120# weight loss. The fine print was that included getting rid of factory power steering and power disc brakes. If you already had manual steering almost all the weight was the brakes.
