Re: A833 stamping ID numbers
[Re: hemienvy]
#3039231
05/03/22 12:11 AM
05/03/22 12:11 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
18 or 23-spline? it is from a 1970 Lynch Rd. Plymouth B-body that was "scheduled" 12/19/69if the stamping is accurate "3084" is 1/6/70 - - the car was built a little LATE
[Re: hemienvy]
#3039941
05/05/22 11:31 AM
05/05/22 11:31 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
Thanks 6BBL, it's a 23-spl. Does it have a big block size bearing retainer or small block ?
[Re: hemienvy]
#3040011
05/05/22 03:52 PM
05/05/22 03:52 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
1970 was the first year that Mopar had N.P. change the tail shaft housing to dual shifter mounts to fit both the B and E bodies: up: scope:
[Re: 6bblgt]
#3040215
05/06/22 08:35 AM
05/06/22 08:35 AM
JohnRR
U.S.S.A.
there are NOT any 318 4-speed or 340 4-speed B-bodies for 1970 - from a 383HP car Thanks for the info , wasn't sure if it was still a thing for 70. What about 383-2 bbl , did they carry over to 1970? With this in mind it's from a 70 Roadrunner, or lower models that were available with a 383 .
