Anyone have a failure that this might have saved? #3038845
05/01/22 06:26 PM
05/01/22 06:26 PM
IL
furious70 Offline OP
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Anyone have a failure that this might have saved? [Re: furious70] #3039032
05/02/22 10:26 AM
05/02/22 10:26 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Interesting. work Like a girdle, or something? wrench
Re: Anyone have a failure that this might have saved? [Re: bobby66] #3039072
05/02/22 12:38 PM
05/02/22 12:38 PM
IL
IL
supposedly helping add back support the monster cast OEM pans provide like a girdle, yes.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Anyone have a failure that this might have saved? [Re: furious70] #3039089
05/02/22 01:30 PM
05/02/22 01:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't think it is helping strengthen the block like a main girdle and not all the stock oil pans are cast. The only thing I see it doing is a little strength to support the transmission as well as noise suppression witch I would be it the real reason the factory has them... I bolted the one on my 2011 ram while it was running and it was impressive how much quieter the trans sounded while bolting it on, same with the stupid plastic cover on top of the intake.
Re: Anyone have a failure that this might have saved? [Re: HotRodDave] #3039139
05/02/22 04:32 PM
05/02/22 04:32 PM
BDW Offline
BDW  Offline
Don't you need to grind block on driver side to clear starter?
This interferes even more?
Re: Anyone have a failure that this might have saved? [Re: furious70] #3044450
05/22/22 09:47 PM
05/22/22 09:47 PM
SWFL
Tie Rod Garage Offline
SWFL
a stock support can be modified to clear any aftermarket oil pan. it's especially easy if you have a mill, but a grinder will work.
1941 Dodge WC, 493 cid twin turbo FAST XFI
2002 Dakota R/T RC
