Re: Anyone have a failure that this might have saved?
[Re: bobby66]
#3039072
05/02/22 12:38 PM
05/02/22 12:38 PM
Posts: 2,255 IL
furious70
IL
supposedly helping add back support the monster cast OEM pans provide like a girdle, yes.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#3039089
05/02/22 01:30 PM
05/02/22 01:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't think it is helping strengthen the block like a main girdle and not all the stock oil pans are cast. The only thing I see it doing is a little strength to support the transmission as well as noise suppression witch I would be it the real reason the factory has them... I bolted the one on my 2011 ram while it was running and it was impressive how much quieter the trans sounded while bolting it on, same with the stupid plastic cover on top of the intake.
[Re: furious70]
#3044450
05/22/22 09:47 PM
05/22/22 09:47 PM
Posts: 20 SWFL
Tie Rod Garage
SWFL
a stock support can be modified to clear any aftermarket oil pan. it's especially easy if you have a mill, but a grinder will work.
1941 Dodge WC, 493 cid twin turbo FAST XFI 2002 Dakota R/T RC
