Support trans without engine #3038681
05/01/22 06:46 AM
05/01/22 06:46 AM
BDW Offline OP
BDW  Offline OP
I pulled the motor and put a couple blocks of wood under the trans pan to support the front of the transmission.
But now I'd like to move the car.
Any ideas on a way to hold up the trans while I move the car around on wheel dollies?
Thx
Re: Support trans without engine [Re: BDW] #3038690
05/01/22 07:53 AM
05/01/22 07:53 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I used a coat hanger or wire thru bell housing bolt hole, up and around master cylinder on 1 side, and to a bolt or stud sticking out of fire wall on passenger side.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Support trans without engine [Re: BDW] #3038698
05/01/22 08:42 AM
05/01/22 08:42 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I put something soft like folded up blankets or similar on top of each fender and then lay a 2 x 4 across fender to fender. Then I wire up the bellhousing to the 2 x 4.
Re: Support trans without engine [Re: BDW] #3038715
05/01/22 10:03 AM
05/01/22 10:03 AM
IMGTX Offline
IMGTX  Offline
I use a ratchet strap between the T bars to hold it up.
I have also used angle iron with holes drilled for ubolts to hold it to the T bars. I then bolted the angle iron to the front of the transmission but once I started using ratchet straps I found it overkill.
If you attach anything to the T bars make sure they don't have sharp edges to scratch them but it isn't hard to deal with.
Re: Support trans without engine [Re: IMGTX] #3038720
05/01/22 10:23 AM
05/01/22 10:23 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
How far do you have to move the car ?
All of the above will work.
Using the aprons or t-bars & preventing scratches is what I prefer.
I like to keep the trans from moving.
Re: Support trans without engine [Re: topside] #3038731
05/01/22 10:56 AM
05/01/22 10:56 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I seen a lot of people run a cable or something between a hole in the bell housing to the lower stud on the wiper motor. Not that i ever used this method.
Re: Support trans without engine [Re: Moparite] #3038736
05/01/22 11:15 AM
05/01/22 11:15 AM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
put 2 phillips screwdrivers, 1 on each side , in the bellhousing/starter holes and a 2x4 or pipe across the torsion bars.
Re: Support trans without engine [Re: trw1982] #3038744
05/01/22 11:34 AM
05/01/22 11:34 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have apiece of light angle iron and a pair of bolts just like IMGTX.
Re: Support trans without engine [Re: slantzilla] #3038766
05/01/22 01:12 PM
05/01/22 01:12 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
2x4 across the fenders (with a rag underneath each side) and steel cable through the bellhousing bolt holes. Use crosby clamps to secure the cable looped around the 2x4. This is at least how I did it.
Re: Support trans without engine [Re: IMGTX] #3038775
05/01/22 01:48 PM
05/01/22 01:48 PM
i use ratchet straps also up scope twocents
Re: Support trans without engine [Re: BDW] #3038795
05/01/22 02:59 PM
05/01/22 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Support trans without engine [Re: John_Kunkel] #3038820
05/01/22 04:59 PM
05/01/22 04:59 PM
BDW Offline OP
BDW  Offline OP
Thx for all the replies, wasted an hour rigging up a bolt in the firewall for a coat hangar.
Then I look in all the closets and no wire hangars.......
Ended up with a piece of wood and that worked really nice.
At the rate I’m going this engine swap is going to take forever.
I spend more time McGyvering things and it never ends.
I envy you guys that have a shop set-up for this stuff.
Thx
Re: Support trans without engine [Re: BDW] #3038855
05/01/22 06:56 PM
05/01/22 06:56 PM
AndyF Online content
AndyF  Online Content
Come on over, plenty of room in my shop to work on a Mopar.
Re: Support trans without engine [Re: BDW] #3038863
05/01/22 07:27 PM
05/01/22 07:27 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The "shop" I've been using the last 20 years is a 2 car garage with an 8' high ceiling. A lot of stuff gets done outside, then rolled into the garage. You do whatever you have to do to get the job done, making special stuff is just part of the job.
The trick is once you make a special "tool" to make something work, label it and hang it on the wall for the next time you need to do the same thing.
