Support trans without engine
#3038681
05/01/22 06:46 AM
05/01/22 06:46 AM
Posts: 4,707 Florida
BDW
I pulled the motor and put a couple blocks of wood under the trans pan to support the front of the transmission. But now I'd like to move the car. Any ideas on a way to hold up the trans while I move the car around on wheel dollies?
Thx
Re: Support trans without engine
[Re: BDW]
#3038690
05/01/22 07:53 AM
05/01/22 07:53 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I used a coat hanger or wire thru bell housing bolt hole, up and around master cylinder on 1 side, and to a bolt or stud sticking out of fire wall on passenger side.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: trw1982]
#3038744
05/01/22 11:34 AM
05/01/22 11:34 AM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
I have apiece of light angle iron and a pair of bolts just like IMGTX.
[Re: slantzilla]
#3038766
05/01/22 01:12 PM
05/01/22 01:12 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
2x4 across the fenders (with a rag underneath each side) and steel cable through the bellhousing bolt holes. Use crosby clamps to secure the cable looped around the 2x4. This is at least how I did it.
