67 RT Power Brake Booster #3038054
04/28/22 09:18 PM
04/28/22 09:18 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
My power brake booster has a vacuum leak. I’m not sure the proper part to replace it with. My car had stock power disk brakes And the calipers, rotors etc. were changed to a master power brake unit. I don’t think the master cylinder and booster were changed at the time. What do I replace this with? Pardon my ignorance
Re: 67 RT Power Brake Booster [Re: p d'ro] #3038063
04/28/22 09:58 PM
04/28/22 09:58 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
https://www.carid.com/right-stuff-d...html?singleid=344208073&url=16500106
I was looking at this one. I have never installed one but know there may be an issue with length of rod for pedal?
Re: 67 RT Power Brake Booster [Re: p d'ro] #3038150
04/29/22 08:38 AM
04/29/22 08:38 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The problem with a '67 B-Body with disc brakes is that they all used the 'Hemi' offset booster regardless of what motor was installed. I am not sure just what you have there but you should have a bracket assembly between the booster and the firewall. If you do, have your booster rebuilt by someone like Power Brake Booster (https://boosterdeweyexchange.com/). I can't comment on alternatives as I only have worked with the stock setup. Here is a picture of what your bracket should look like if you have the stock assembly.
Re: 67 RT Power Brake Booster [Re: 6PakBee] #3038206
04/29/22 12:01 PM
04/29/22 12:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Didn't know that about the 67 booster, thanks .
Re: 67 RT Power Brake Booster [Re: p d'ro] #3038207
04/29/22 12:04 PM
04/29/22 12:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It has and adjustable rod from looking at the picture , maybe you could swap on your rod or just bolt it onto your bracketry ?
If you're concerned with originality you should send your original out and get it rebuilt .
Re: 67 RT Power Brake Booster [Re: p d'ro] #3038513
04/30/22 03:04 PM
04/30/22 03:04 PM
robertop Offline
robertop  Offline
If your booster has a leak, why not rebuild it?There are few outfits that have been doing that for decades, no problems. Only hurts your pocketbook.
