Re: 67 RT Power Brake Booster
[Re: p d'ro]
#3038150
04/29/22 08:38 AM
04/29/22 08:38 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
The problem with a '67 B-Body with disc brakes is that they all used the 'Hemi' offset booster regardless of what motor was installed. I am not sure just what you have there but you should have a bracket assembly between the booster and the firewall. If you do, have your booster rebuilt by someone like Power Brake Booster ( https://boosterdeweyexchange.com/). I can't comment on alternatives as I only have worked with the stock setup. Here is a picture of what your bracket should look like if you have the stock assembly.
[Re: 6PakBee]
#3038206
04/29/22 12:01 PM
04/29/22 12:01 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
The problem with a '67 B-Body with disc brakes is that they all used the 'Hemi' offset booster regardless of what motor was installed. I am not sure just what you have there but you should have a bracket assembly between the booster and the firewall. If you do, have your booster rebuilt by someone like Power Brake Booster ( https://boosterdeweyexchange.com/). I can't comment on alternatives as I only have worked with the stock setup. Here is a picture of what your bracket should look like if you have the stock assembly. Didn't know that about the 67 booster, thanks .
[Re: p d'ro]
#3038207
04/29/22 12:04 PM
04/29/22 12:04 PM
JohnRR
U.S.S.A.
It has and adjustable rod from looking at the picture , maybe you could swap on your rod or just bolt it onto your bracketry ? If you're concerned with originality you should send your original out and get it rebuilt .
