No Trunk Lip Vin Stamping, Ideas Why? #3037712
04/27/22 07:31 PM
04/27/22 07:31 PM
Salem, NY
69gtxvert Offline OP
Salem, NY
As you might guess from my user name, the car I'm referring to is a 1969 GTX Convertible. I've had it since 1996 and wasn't too concerned about numbers when I bought it. If it matters, the VIN is RS27L9G294124 which is shown on the fender tag, the cowl tag and the radiator support. the transmission matches but the engine does not. I have not found a build sheet. I'm within a year or two of getting the car back to being a pretty decent driver before I give it to my son (sentimental value - he used it in his wedding) and wanted to pass along as much detail about the car as I can. I finally pulled off the trunk weather strip to look for the VIN stamping on the trunk lip and the only stamping I can find looks like a part number stamped from the underside. There is nothing resembling a partial VIN. Ideas?
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 69gtxvert] #3037725
04/27/22 08:11 PM
04/27/22 08:11 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Where are you looking for it? Any photos of the area where you think it should be?
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 69gtxvert] #3037726
04/27/22 08:13 PM
04/27/22 08:13 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
All the doomsayers here will now tell you it is not numbers matching, DAMHIK! eyes I have seen several cars with either no core support stamp or trunk stamp, usually will have one or the other, never seen one with no stamps 69-up. It may be so light you won't see it, or they might have left it off. Some are so faint that you need to take the rail down to bare metal and still use an led light to see it! scope
JB Rhinehart, Realist
A-Body's RULE!
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: Rhinodart] #3037731
04/27/22 08:23 PM
04/27/22 08:23 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
What you were told was that someone wanting to spend numbers matching money on a vehicle would pass on one without a vin stamp on the core support.
What you imagined I can't say.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: Rhinodart] #3037734
04/27/22 08:27 PM
04/27/22 08:27 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
No dooms dayer here, just an observation. Lack of discernible stampings do not change the history of the car, simply may affect one's perception of originality.
This includes current owner and prospective buyers.
Many cases here on moparts where stamps were lacking and even a well disclosed (barrelcuda) migration of numbers.
Anything but complete documentation always raises eyebrows.
It's almost to some there is no middle ground between numbers well documented and clone. Personally think there is a lot of middle ground..
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: srt] #3037736
04/27/22 08:35 PM
04/27/22 08:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Personally, I am not a numbers matching guy, well I do expect the numbers on the title to match the numbers on the car, lol. Other than that I don't care. I buy a car if it's something I want and the price is reasonable to me.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: srt] #3037738
04/27/22 08:37 PM
04/27/22 08:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As A12 said, where are you looking?
Should be on left quarter weatherstrip rail, forward of the bolt-on quarter extension.
Possible explanations:
Forgotten at factory
Quarter replaced or heavily reworked
Weatherstrip rail replaced
Even in worst-case scenario - car was clipped, built/rebuilt from a different car - unless someone worked that area, SOME partial VIN should be there.
Unless it was missed at the factory.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: Sniper] #3037741
04/27/22 08:43 PM
04/27/22 08:43 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
And will ask, What are the chances that 1/4 may have been replaced early in it's life ?
Or having been on the line myself back in the there are a multitude or reasons it just flat didn't get stamped or stamped in a place your not looking.
With rhino's comments maybe it was sandblasted off
shruggy twocents beer
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: topside] #3037747
04/27/22 08:48 PM
04/27/22 08:48 PM
Salem, NY
Salem, NY
I've looked over the entire trunk lip by now but really, the focus was on the driver's side. I've scraped, wire-brushed and finally sanded weatherstrip adhesive and paint off but all I can see is an obscure part number. I'll try to post a pic tomorrow when I get back to the garage. I don't know what may have been done before '96 as far as quarter panel replacement goes. The current quarter panel isn't in great shape so if it is a replacement, it didn't hold up well. Also, it doesn't look replaced - undercoating looks original, etc. Thanks for the feedback.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 69gtxvert] #3037815
04/27/22 11:35 PM
04/27/22 11:35 PM
My early production (sold new in Nov. of 1968) 1969 Dart GTS 383 car has the sequence number stamped on the trunk lid where your looking, it has the sequence stamped upside down on the radiator core support also, not the complete VIN numbers shruggy
I bought the car the first time in 1991 and bought it back in 2009 or so after selling it in 2002 shruggy
that car came with one major factory stamping error new from the factory that I know of, it is on the dash VIN TAG, the 2 or 3 is directly stamped over the other number in the middle of where they both should not be shruggy
my message is the factory is operated by humans and they do MAKE MISTAKES now and then shruggy
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: Cab_Burge] #3037841
04/28/22 12:34 AM
04/28/22 12:34 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Don’t know if changed for that year but my 66 is on the panel that connects the quarters behind rear bumper.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: cudaman1969] #3037863
04/28/22 07:23 AM
04/28/22 07:23 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There are really only a few choices here:
1) Never was stamped
2) Was replaced with OEM parts
If it was a component from another car, one would think that would have been stamped with that car's ID.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 6PakBee] #3037974
04/28/22 01:25 PM
04/28/22 01:25 PM
Salem, NY
Salem, NY
Will try to post a pic of the only number stamping I could find on the left side trunk lip. I believe the number is 2838511. A similar number, 2838510, is stamped on the passenger side.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 69gtxvert] #3037978
04/28/22 01:51 PM
04/28/22 01:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You're close to finding it if it's there which I'm betting it is. Go right above the part number stamp and a little forward or to your photo's right (between the white lines) and remove a lot or most of the paint. (you can just see the number 2838511 stamped from underneath on my Y4 A12 photo below my trunk lip number so you're in the right church just in the wrong pew)
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: 69gtxvert] #3037985
04/28/22 02:18 PM
04/28/22 02:18 PM
AndyF Online content
AndyF  Online Content
Most cars got the VIN stamp but the assembly line in the late 60's wasn't exactly like a modern Toyota line. Maybe the guy was taking a smoke break or in the john when you car came down the line. If you can't find it then it probably isn't there. You should be able to tell if the quarter was replaced since typically they didn't do a very neat job of hanging those back in the day.
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: AndyF] #3037988
04/28/22 02:35 PM
04/28/22 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
As said, things were loose back then and mistakes were made, but there seems to be a very faint ghost of something visible in the picture.
Hard to tell since pictures get a pixelated appearance when zoomed, but this is where my '69 GTX number is located relative to the part number stamp.
A9 (space) 127XXX.
It appears if a little more paint was removed yours might be visible enough to make it legible. It's pretty faint but looks like there might be something there. You just need to focus on the lip instead of the spot inside of the lip….
Rich H.
Esse Quam Videri
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: AndyF] #3037990
04/28/22 02:51 PM
04/28/22 02:51 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think or betting it's there............I did a little photoshopping on his photo and I swear I could almost see a character or two up above where my stamping is scope I have a long story about Calvin Smith's A12 Super Bee at the Nat's when it was first ever judged. The judges couldn't read the radiator support numbers so the told Calvin's friend to find the trunk lip numbers and they won't take points away. I was sitting with Calvin at the time when the friend came over to explain he needed to search for the trunk lip numbers where the judges told him he would find them on the RIGHT SIDE trunk weatherstrip lip toward the right front. I had a tracing of my A12 trunk lip with me and told Calvin and his friend that the numbers are on the LEFT side two thirds of the way back and near that part number. Calvin told his friend to listen to me and we went over and peeled the weatherstrip off and the friend pulled out his pocketknife and just then two judges came back. Both started to tell the friend "You're in the wrong place, it's on the RIGHT" The friend looks at me and I assured him where to scrape and that whatever paint he scrapes off will be covered by the weatherstrip so no one will see it. He starts scrapping as the judges shake their heads and then the "A" appears. He scrapes the paint off of the rest of the characters and doesn't lose any points.........................and goes on to be the top car for the year by only one point. I always felt that Calvin owed me at least a beer for that win laugh2 Fast forward to when the owner that bought Calvin's A12 at BJ posted it for sale and included the trunk lip number photo where no one ever painted the scraped of paint from that day at the Nat's.
Mike
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: A12] #3037995
04/28/22 03:18 PM
04/28/22 03:18 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My story on Calvin Smith's A12 Super Bee "can't be true unless you (me) have photos" well ........with the judges standing next to Calvin's friend Vic
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: A12] #3038003
04/28/22 04:01 PM
04/28/22 04:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What caused something like this to happen? I couldn't even imagine telling someone whose car I was judging that they had to pull up the weatherstripping AND scrape off the paint to check a number ?
Re: No Trunk Lip Vin Stamping, Ideas Why? [Re: A12] #3038007
04/28/22 04:14 PM
04/28/22 04:14 PM
Salem, NY
Salem, NY
I went back and scraped some more paint off and there doesn't seem to be anything there. Thanks for everyone's input and patience with my lousy pics. Hope this one is a little better than the first one. I'm not going to sweat it too much. I'll let my son know what you guys offered up in case he ever decides to sell (he says "no way!") Thanks again for weighing in.
