Page 4 of 4 1 2 3 4
Re: 572 B1 engine install [Re: Clanton] #3037321
04/26/22 06:21 PM
04/26/22 06:21 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Very Nice ! Where's the like button ?
Re: 572 B1 engine install [Re: moparacer] #3037367
04/26/22 08:57 PM
04/26/22 08:57 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Originally Posted by moparacer
How much oil pressure are you running?
I have only run this engine for a few minutes (several short runs) in the garage before the hex drive broke.
Since the oil was still cold, it made plenty of oil pressure. This pump and relief valve spring typically made 60-65 psi with warm oil and higher than idle type RPM.
I didn't notice any oil pressure issues until it went to zero. confused
I expect to start it again on Wednesday. The investigation is done, the new bronze gear oil pump drive shaft is installed, and I put a new oil pump in just in case.
I primed it with a drill late today (Tuesday) and it all seems normal. luck
Re: 572 B1 engine install [Re: 440Jim] #3037557
04/27/22 10:44 AM
04/27/22 10:44 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good comeback from the freak failure.
I heard of one other brand new MP intermediate shaft snapping like that at a local race shop, close to 20 years ago.
The builder scrapped it, put in a different brand and never had another issue.
Thinking it has to be bad heat treat or similar, like the guys are saying. Just glad to see you caught it now!
Rich H.
Esse Quam Videri
Re: 572 B1 engine install [Re: ZIPPY] #3037629
04/27/22 03:14 PM
04/27/22 03:14 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
OK, things went well this afternoon.
- I primed the engine with a drill (again), before installing the oil pump drive and distributor.
- The engine fired right up ! wrench And oil pressure was 70 psi at 1700 rpm. up
- After running a few minutes in the garage, I turned it off and checked for anything unusual. Looked fine.
- Started again and drove up and down the driveway 4 times to check the transmission in all gears, including reverse.
This was the first drive with my PG since I put the 1.80 straight cut planetary gears in it (was stock 1.76). All good.
- After letting it cool in the garage and doing more checks; I drove it up and down the driveway a couple more times for fun. drive
Good day all around. Sunny, 60 degrees; and the car moves!
Re: 572 B1 engine install [Re: 440Jim] #3037632
04/27/22 03:20 PM
04/27/22 03:20 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Awesome!
Always a good thing when it goes smoothly.
'63 Dodge 330
11.19 @ 121 mph
Re: 572 B1 engine install [Re: 440Jim] #3037642
04/27/22 03:39 PM
04/27/22 03:39 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Great news. Do you have a trip to the track planned soon.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 572 B1 engine install [Re: pittsburghracer] #3037644
04/27/22 03:43 PM
04/27/22 03:43 PM
an8sec70cuda Offline
Any new black marks in the driveway? drive
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 B1 engine install [Re: an8sec70cuda] #3037653
04/27/22 04:07 PM
04/27/22 04:07 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
LOL,
I am too much of a neat freak to put tire marks on my new concrete driveway.
Unfortunately, no local tracks have a test and tune this week. Usually two tracks have Thurs evening T&T, but they are having special events all week.
And Farmington typically has a Friday night test session with motorcycles, street cars, etc. But I don't know what the surface is like with mainly street cars and motorcycles.
GALOT Motorsports Park - Spring Fling Big Dollar racing.
I may be able to Test at Piedmont, if they allow it during their Tuesday or Thursday special events (May 3 or 5). I need to phone them.
Farmington Dragway has a Mopar event Sat May 7.
Re: 572 B1 engine install [Re: 440Jim] #3037680
04/27/22 05:33 PM
04/27/22 05:33 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Well done Jim, you put in a really big effort with that engine. the car looks great also. hope it runs well. Rob.
Re: 572 B1 engine install [Re: 572B1] #3037688
04/27/22 06:19 PM
04/27/22 06:19 PM
gregsdart Offline
gregsdart  Offline
Good to hear you are ready to roll, Jim! Time for fun!
Page 4 of 4 1 2 3 4
