Pegboard to hang hand tools? Hardboard, metal or other? #3036490
04/23/22 11:45 PM
04/23/22 11:45 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Inquiring to see how many Moparts Members like pegboard to hang hand tools? If so what type of material did you use/recommend for a insulated/drywalled garage?
Anyone have the pegboard attached to their workbench or freestanding?
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: vinnyd76] #3036493
04/24/22 12:10 AM
04/24/22 12:10 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I used to have a section of pegboard on the wall behind my workbench. It was roughly 3'X6'. I used the typical pegboard wood/fiberboard (not sure what you call it). I made a 'frame' out of 1X3's kinda in the shape of a capital 'E' laying face down leaving the bottom 'open' so that dirt and crap wouldn't collect between the pegboard and wall (I hope that made sense)to mount the peg board on to hold it away from the wall so the hooks could be installed. I never hung anything real heavy, just the typical wrenches, screw drivers, etc, etc. Never had any issues.
Too bad you're not closer, while my pegboard is gone, I still have a box of hooks that I'd be willing to donate.
John
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: SattyNoCar] #3036499
04/24/22 02:49 AM
04/24/22 02:49 AM
5thAve Offline
5thAve  Offline
I have pegboard behind my work bench, it's also the normal wood stuff they all used to be made out of. The walls behind it are the old 60s/70s style paneling that won't hold any weight so each end of the pegboard has a 2X2 leg that it stands on sandwiched between the work bench and wall. It's a mix of typical tools and oddball stuff, mostly non car stuff.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: 5thAve] #3036516
04/24/22 08:24 AM
04/24/22 08:24 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you had a store near you that went belly up or remodeled, the gondola style pegboard is the way to go. I haven't mounted it yet but I got quite a bit when the local NAPA store remodeled. Advantage of this stuff is that is has a metal frame which should make mounting easier.
Gondola Pegboard
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: vinnyd76] #3036550
04/24/22 11:23 AM
04/24/22 11:23 AM
AndyF Offline
AndyF  Offline
Pegboard works okay for awhile. It lasts a lot longer if you have a heated shop. In an unheated shop the moisture will eventually weaken it and then it starts to bend and bow. It is a handy way to hang some stuff up. Works best if you retain the hooks to the pegboard so they don't fall out when you remove the tools.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: 6PakBee] #3036553
04/24/22 11:35 AM
04/24/22 11:35 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have always used the wood peg board and it works well! If you want it to have a different look paint it to match the design of your garage cabinets or tool boxes.
My Monster are real!
Living within your means makes life pretty easy.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: vinnyd76] #3036558
04/24/22 12:07 PM
04/24/22 12:07 PM
IMGTX Offline
IMGTX  Offline
I have a section of the wood pegboard on which I hang several standard type hammers, and on one long peg I have about six 12 to 14" adjustable wrenches and have not had a problem.
I would imagine if the I started hanging my 5lb sledges on it I would have problems but these pegs have been on that board for over 20 years.
I did discover there are two sizes of pegs and pegboards. I have some of the smaller pegboard for little things like parts in the store hanging packaging but for the tools I have the larger pegs.
One is like 3/16" and the other is 1/4" to 5/16" It is noticeable and the pegs do not interchange.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: IMGTX] #3036620
04/24/22 03:22 PM
04/24/22 03:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer the larger 1/4" myself. Have it in a couple areas of my shop.
You can also buy small racks & bins for it, which are handy.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: vinnyd76] #3036778
04/25/22 02:21 AM
04/25/22 02:21 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Pegboard should never have outlines of tools painted on the surface.
I have a small amount above a small bench in the garage. In the shop, never.
In the garage I have things like scissors, padlocks, keys, a crescent wrench, and a few other things.
To mount I did not use the spacers, rather I ripped some 1/2" plywood and ran it across the top and bottom and added a few verticals, That all was glued and tacked with brads Back primed and front finished with high gloss spray with primer.
I plan to take it out as it still collects dust and what not. Plan to put up hard faced plywood and simply (slant)drill and insert 1/8" rod cut to whatever length Being able to install a few small shelves and a key/lock cabinet prompted this new plan.
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: srt] #3036821
04/25/22 08:37 AM
04/25/22 08:37 AM
moparx Offline
moparx  Offline
i have a small section of peg board in the garage that was there when we moved in.
i just have a small selection of little used tools and items on it.
if i were to remodel the garage [will never happen at this stage of my game. biggrin] i would leave the peg board out.
beer
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: vinnyd76] #3049451
06/10/22 04:30 PM
06/10/22 04:30 PM
northeast
bfly Offline
bfly  Offline
northeast
Vinnyd76,
Trying to contact you about wiring harness. Pm me when you get a chance
Re: Pegboard to hang hand tools? Hardboard, metal or other? [Re: bfly] #3049490
06/10/22 08:38 PM
06/10/22 08:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I have 2 sections of the particle board peg boards in my garage. They were there when I moved in and have been there over 20 years. They have seen the full load of abuse for 20+ years. There have been a couple places where a few of the 6" long pegs were a bit overloaded and did pull through (couldn't hold the 50' torch hose coiled over it more then a couple of years, or 6 of the 11" vice grips on one peg more then 10 years). My peg boards are attached to the wall with 6 long screws into the studs with a 3/4" nut spacing the board away from the wall, the boards are 4' x 4', and there was no other support, but I've relocated those support locations from the original holes. The one panel gets more heavy stuff the the other one does because of its location. The garage is pretty dry, and is heated, but is does see humidity when its humid outside. There is some droop in the boards themselves, and over the years I've moved the mounting screws to different locations. Those boards are still loaded pretty full to this day.
The pic was taken in 2021, but it still looks about the same today. The torch hose still hangs off the pegboard (different holes), but I'm a lot more gentle removing and hanging up back up.
