518/727 help please
#3036236
04/23/22 09:39 AM
04/23/22 09:39 AM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
did a search with no luck 3800lb car with 800whp turbo built WELL 518, full auto valve body launch fine, 1-2 shift fine, 2-3 had an rpm spike before shifting, didnt feel like a slip. more like brief neutral then drive.. trapped at 148mph. drove home fine both leaving in drive and shifting manually any ideas
Re: 518/727 help please
[Re: mcat4321]
#3036253
04/23/22 10:16 AM
04/23/22 10:16 AM
Posts: 3,069 Michigan
A727Tflite
did a search with no luck 3800lb car with 800whp turbo built WELL 518, full auto valve body launch fine, 1-2 shift fine, 2-3 had an rpm spike before shifting, didnt feel like a slip. more like brief neutral then drive.. trapped at 148mph. drove home fine both leaving in drive and shifting manually any ideas Who built the trans.
[Re: mcat4321]
#3036291
04/23/22 12:36 PM
04/23/22 12:36 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How long since you adjusted the kickdown band?
[Re: A727Tflite]
#3036293
04/23/22 12:43 PM
04/23/22 12:43 PM
mcat4321
cincinnati ohio
did a search with no luck 3800lb car with 800whp turbo built WELL 518, full auto valve body launch fine, 1-2 shift fine, 2-3 had an rpm spike before shifting, didnt feel like a slip. more like brief neutral then drive.. trapped at 148mph. drove home fine both leaving in drive and shifting manually any ideas Who built the trans. russell with all aa parts
[Re: A727Tflite]
#3036356
04/23/22 03:19 PM
04/23/22 03:19 PM
mcat4321
cincinnati ohio
Call Russell.
He owes you. absolutely, but considering this occurred last night, i figured i'd pick some brains until monday.
[Re: mcat4321]
#3036383
04/23/22 04:10 PM
04/23/22 04:10 PM
A727Tflite
Call Russell.
He owes you. absolutely, but considering this occurred last night, i figured i'd pick some brains until monday. It’s called 2-3 flare. Could be something simple or something inside the trans. You will get all kinds of suggestions here - I would trust your trans tech to set you straight. You owe him the courtesy.
