Re: Teflon sealing rings for input shaft.
[Re: racerx]
#3035970
04/22/22 11:38 AM
04/22/22 11:38 AM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Bone stock. Metal rings are okay, if that's all you have. Anything else, teflon.
[Re: Moparteacher]
#3035991
04/22/22 12:14 PM
04/22/22 12:14 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
I only use steel now, as in the past I have melted Teflon rings being on trans brake at 5500 rpm with pro tree
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3036112
04/22/22 07:45 PM
04/22/22 07:45 PM
Posts: 4,071 Mo.
racerx
Mo.
I only use steel now, as in the past I have melted Teflon rings being on trans brake at 5500 rpm with pro tree Guess i should have mention this is a transbreake race transmission, with aftermarket drum, if that even matters, I'm getting ready to pull the trigger on some parts from john cope transmission.
