Teflon sealing rings for input shaft. #3035965
04/22/22 11:17 AM
04/22/22 11:17 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is it worth it? or should i just install the steel rings in the kit? In the process of assembling this transmission work
Re: Teflon sealing rings for input shaft. [Re: racerx] #3035970
04/22/22 11:38 AM
04/22/22 11:38 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Bone stock. Metal rings are okay, if that's all you have. Anything else, teflon.
Re: Teflon sealing rings for input shaft. [Re: racerx] #3035972
04/22/22 11:40 AM
04/22/22 11:40 AM
Boise
Moparteacher Offline
Boise
The teflon rings expand to fill the groove and do not wear the stator support like the steel rings will. But, the steel rings work fine if the groove in the shaft is not damaged. Check side clearance with a feeler gauge the same way you would piston ring side clearance.
Re: Teflon sealing rings for input shaft. [Re: Moparteacher] #3035991
04/22/22 12:14 PM
04/22/22 12:14 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I only use steel now, as in the past I have melted Teflon rings being on trans brake at 5500 rpm with pro tree
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Teflon sealing rings for input shaft. [Re: 440lebaron] #3036110
04/22/22 07:44 PM
04/22/22 07:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Teflon are a no no with aluminum drums. The steel will work very well if you lap the grooves in the stator support. If the grooves are tapered the rings will wear on the side. Never had any issue with either style on the input shaft.
Doug
Re: Teflon sealing rings for input shaft. [Re: 440lebaron] #3036112
04/22/22 07:45 PM
04/22/22 07:45 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Guess i should have mention this is a transbreake race transmission, with aftermarket drum, if that even matters, I'm getting ready to pull the trigger on some parts from john cope transmission.
Re: Teflon sealing rings for input shaft. [Re: dvw] #3036116
04/22/22 08:05 PM
04/22/22 08:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Doug
Thanks For that advice Doug. up
