Isky cam numbers #3034246
04/16/22 09:15 PM
04/16/22 09:15 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
A friend of mine has an older Isky roller cam that I am interested in and I'm trying to get the specs on it. It has the numbers X032277 2 Bd RR-483 1651 or 1681 etched into the end.
I have done a little research on my own but I couldn't come up with much information
Thank you
Gus beer
64 Plymouth Savoy
Dana 60
Re: Isky cam numbers [Re: fourgearsavoy] #3034293
04/17/22 12:49 AM
04/17/22 12:49 AM
Call Isky with those number Monday Morning 323-770-0930 scope
Re: Isky cam numbers [Re: fourgearsavoy] #3034295
04/17/22 01:00 AM
04/17/22 01:00 AM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
I'm in same boat, I have an old Isky solid flat tappet cam.
Isky has been zero help.
Re: Isky cam numbers [Re: hemienvy] #3034424
04/17/22 02:48 PM
04/17/22 02:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d measure the lobe lift to see if it corresponds with the “483”.
I see 3 different roller lobes in there catalog that have .483” lobe lift.
There is also a lobe number R-483 which is .350” lift(street roller).
Re: Isky cam numbers [Re: fast68plymouth] #3034562
04/17/22 11:02 PM
04/17/22 11:02 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
The website is crap but might be useful to download the catalogue,page 126
