Isky cam numbers
#3034246
04/16/22 09:15 PM
04/16/22 09:15 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
A friend of mine has an older Isky roller cam that I am interested in and I'm trying to get the specs on it. It has the numbers X032277 2 Bd RR-483 1651 or 1681 etched into the end. I have done a little research on my own but I couldn't come up with much information Thank you Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Isky cam numbers
[Re: hemienvy]
#3034424
04/17/22 02:48 PM
04/17/22 02:48 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d measure the lobe lift to see if it corresponds with the “483”. I see 3 different roller lobes in there catalog that have .483” lobe lift.
There is also a lobe number R-483 which is .350” lift(street roller).
