Check Gascap Message #3033188
04/13/22 02:33 PM
04/13/22 02:33 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
My 2006 Magnum RT AWD is bringing up "Check Gascap" message in the EVIC . . . it's not setting any codes or turning on the MIL (check engine light) . . . just that darn message . . . I have put a NEW gas cap on the car, no change . . . any ideas would be appreciated . . . I know it has to do with the EVAP emissions, but there aren't any codes coming up . . . everything else totally 100% with the car . . .
Thoughts . . . .?????
Re: Check Gascap Message [Re: a12rag] #3033196
04/13/22 02:49 PM
04/13/22 02:49 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
There's a leak in the evaporative system. Find someone with a smoke machine to locate the leak, probably an old rotten hose?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Check Gascap Message [Re: 3hundred] #3033197
04/13/22 02:50 PM
04/13/22 02:50 PM
a12rag Offline OP
a12rag  Offline OP
maybe ? Haven't taken to shop yet . . or had chance to get under to have a look at the hoses . . . funny that this ONLY started AFTER I had taken car in for trans fluid/filter change (have to look at hoses around that area I think) . . .
Re: Check Gascap Message [Re: a12rag] #3033210
04/13/22 03:31 PM
04/13/22 03:31 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Check where the cap seals,just a little rust will set off the message&then the check engine light.Fix a lot of them in ny clean rust with sandpaper coat with vaseline,98% of the time it works.
Re: Check Gascap Message [Re: GarageDodge] #3033219
04/13/22 04:03 PM
04/13/22 04:03 PM
a12rag Offline OP
a12rag  Offline OP
totally clean, no rust . . . checked when put on new cap . . . . and as said, NO Check Engine Light . .. just the message
Re: Check Gascap Message [Re: a12rag] #3033290
04/13/22 06:10 PM
04/13/22 06:10 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Small evap leak in the gas cap area,check hoses in the fuel filler to tank area,might have to have it smoked.
Re: Check Gascap Message [Re: GarageDodge] #3033299
04/13/22 06:31 PM
04/13/22 06:31 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 2012 Challenger does it once awhile. After a few days it goes off and stays off for several months until it reappears again someday.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Check Gascap Message [Re: 6PKRTSE] #3033306
04/13/22 06:56 PM
04/13/22 06:56 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Ancel sells affordable smoke machines that pay for themselves within the first use. I had a vehicle that had failing evap codes all the time and instead of firing the parts cannon, had it smoked to find out the FILLER NECK RUSTED THROUGH. I thought it was very weird until I saw Dorman made new ones.......
Re: Check Gascap Message [Re: a12rag] #3033316
04/13/22 07:25 PM
04/13/22 07:25 PM
IMGTX Offline
IMGTX  Offline
Under the hood is usually a green cap. I have see them down low near the frame too.
Follow the lines to and from it looking for obvious problems. Those lines should go back to the tank and charcoal canister. I have had people crack the canister's with rocks or ??? so I JB Weld (Plastic Weld) the cracks and good to go. A quick look may save the cost of a smoke machine or smoke test.
Re: Check Gascap Message [Re: IMGTX] #3033403
04/14/22 12:11 AM
04/14/22 12:11 AM
New York, USA
Chargerfan68 Offline
New York, USA
Exactly the situation in my case. 2005 grand cherokee 5.7. Evap code and eng light. My buddy smoke tested it at his shop and found the charcoal canister had cracks on it. Vee’d them out and jb welded. All good. Passed inspection. Would have never found it as it was cracked on top of canister. Saw smoke coming from wheelwell area and led us to that location to find it.
Re: Check Gascap Message [Re: Chargerfan68] #3033420
04/14/22 07:47 AM
04/14/22 07:47 AM
md
mopars4ever Offline
mopars4ever  Offline
md
It drove me crazy with the gas cap message thing. Usually it is not the gas cap. Finally found the issue on my 2006 truck and it was the fuel pump module. It was cracked on top.
Re: Check Gascap Message [Re: mopars4ever] #3033442
04/14/22 09:33 AM
04/14/22 09:33 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you research the protocol for the "gas cap alarm", you'll find that it is a fairly complex system. Is it all worth it? I can't see the rational behind it but who am I to question the EPA.
Re: Check Gascap Message [Re: 6PakBee] #3033471
04/14/22 10:36 AM
04/14/22 10:36 AM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
I had a Dakota pickup built during that same era that would kick that alarm/code frequently.
It was usually a split/cracked rubber hose under the car. There are a bunch of them running the length of the car to and from the gas tank, charcoal canister, purge solenoid, etc.
They could be a pain to locate--I didn't have a smoke machine.
Seemed to me there was an issue with the hoses they were using at that time--very poor quality and always cracking.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Check Gascap Message [Re: wingman] #3033487
04/14/22 11:39 AM
04/14/22 11:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The lines running under the car usually are not rubber, they are usually a hard plastic, the only rubber is connections between the hoses and any right angles .
Check the fuel fill pipe, if it is exposed enough to road mist/debris while in motion the tube will probably be corroded pretty bad, even if you live outside the rust belt ... case in point my new to me 1998 Ram 2500 that I got out of Arkansas , there all it's life and only 172k miles , the filler pipe is corroded as bad as my 2000 Ram 2500 that's spent all it's life in New England.
Re: Check Gascap Message [Re: a12rag] #3033511
04/14/22 12:43 PM
04/14/22 12:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My '08 Magnum RT did the same thing and also threw a P0456 - EVAP SYSTEM SMALL LEAK code, turned out to be a faulty ESIM (Evaporative System Integrity Monitor) located under the right rear wheel well cover. Need a smoke machine to find the leak.
Re: Check Gascap Message [Re: a12rag] #3033600
04/14/22 04:13 PM
04/14/22 04:13 PM
GMP440 Offline
GMP440  Offline
Even though no codes are appearing, chances are, a code will set in the future. Two years ago I had an evap code that drove me nuts. I constructed a smoke machine and found no leaks coming from any lines or components of the evap system.
Changed the gas cap for a new one. Still getting the code. I started putting the gas cap really tight. That's when the evap codes went away and never came back. The top part of the fuel filler neck that contacts the rubber gasket of the gas cap had
no rust or corrosion. I figured that the top of the filler neck had fine scratches and allowing the cap not to seal. So, whenever I fuel up I make sure I muscle the gas cap on good. This is on a 97 Buick Regal.
You could have that same issue. Try tightning the gas cap real tight and see what happens.
Re: Check Gascap Message [Re: a12rag] #3033652
04/14/22 07:52 PM
04/14/22 07:52 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The metal sealing ring for the fuel pump and seal into and on top of my wife's 2001 Town and Country fuel tank rusted and whenever we would fill the tank completely there would be a drip of gas on the ground. You could smell the gas strongly if you filled it but otherwise nothing extreme. We replaced the gas cap and still it threw the EVAP leaking gas cap code, until we found the leak at the fuel pump and tank sealing ring. Next time you fill the tank completely check the fuel tank and see if there's a leak at the fuel pump or even if you can smell gasoline.
Re: Check Gascap Message [Re: moparjim79] #3033670
04/14/22 09:44 PM
04/14/22 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Bongs are cheaper and you'll enjoy finding the leak twocents stirthepot
Re: Check Gascap Message [Re: A12] #3034078
04/16/22 10:33 AM
04/16/22 10:33 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Good tips in this thread.
Chrysler EVAP systems certainly seem to leak.
How many years/miles does the EPA require the emissions related equipment warranty to be?
My fuzzy memory is that it was 100,000 miles but got bumped higher?
Re: Check Gascap Message [Re: 360view] #3034108
04/16/22 12:38 PM
04/16/22 12:38 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Vehicles with California emissions equipment have an additional separate warranty mandated by the state of California of 7 years / 70,000 miles from when the vehicle is first put into service, whichever comes first and regardless of ownership. This warranty covers many more parts than the federal warranty. There are also some vehicles that have emission parts covered well beyond the 8 years / 80,000 miles afforded by the Federal Emissions Warranty.
Performance Warranty
The Performance Warranty covers repairs which are required during the first 2 years
or 24,000 miles of vehicle use (whichever first occurs) because the vehicle failed an
emission test. Specified major emission control components are covered for the first
8 years or 80,000 miles (whichever first occurs). If you are a resident of an area with
an Inspection and Maintenance (I/M) program that meets federal guidelines, you are
eligible for this warranty protection provided that:
There are three specified major emission control components, covered for the first 8 years or
80,000 miles of vehicle use (whichever first occurs) on 1995 and newer vehicles:
• Catalytic converters
• The electronic emissions control unit or computer (ECU)
• The onboard emissions diagnostic device or computer (OBD)
