Wiring #3033016
04/12/22 09:20 PM
04/12/22 09:20 PM
florida dade
cesar perez Offline OP
florida dade
What is the simplest wiring harness for a race car
Re: Wiring [Re: cesar perez] #3033041
04/12/22 10:55 PM
04/12/22 10:55 PM
PA
moparacer Offline
moparacer  Offline
PA
ARC 8000D switch panel.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Wiring [Re: cesar perez] #3033046
04/12/22 11:51 PM
04/12/22 11:51 PM
the one you build yourself, no wasted wiring or extra wires to take care of up scope wrench
if you don't know direct current formula for the size wire to use on each circuit, learn it scope
Re: Wiring [Re: moparacer] #3033073
04/13/22 08:43 AM
04/13/22 08:43 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Agreed
Re: Wiring [Re: cesar perez] #3033102
04/13/22 11:18 AM
04/13/22 11:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
magneto ignition and push start.
Re: Wiring [Re: 451Mopar] #3033138
04/13/22 01:04 PM
04/13/22 01:04 PM
haha grin
I remember them days up
Re: Wiring [Re: Cab_Burge] #3033213
04/13/22 03:43 PM
04/13/22 03:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I agree, build it yourself for your specific situation.
Use quality parts. Not auto part store stuff. Read and make sure you understand grounds and good construction techniques. Use Weatherpack at a minimum. Deutsch if you want the good stuff.
I like ARC stuff, but prefer the 3100 panel for most applications. Or build your own with good rocker switches.
