Re: Wiring
[Re: cesar perez]
#3033041
04/12/22 10:55 PM
04/12/22 10:55 PM
Posts: 2,513 PA
moparacer
PA
ARC 8000D switch panel.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: Wiring
[Re: cesar perez]
#3033046
04/12/22 11:51 PM
04/12/22 11:51 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
What is the simplest wiring harness for a race car the one you build yourself, no wasted wiring or extra wires to take care of if you don't know direct current formula for the size wire to use on each circuit, learn it
Re: Wiring
[Re: Cab_Burge]
#3033213
04/13/22 03:43 PM
04/13/22 03:43 PM
Posts: 11,606 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I agree, build it yourself for your specific situation.
Use quality parts. Not auto part store stuff. Read and make sure you understand grounds and good construction techniques. Use Weatherpack at a minimum. Deutsch if you want the good stuff.
I like ARC stuff, but prefer the 3100 panel for most applications. Or build your own with good rocker switches.
