how much rust is too much on a driveshaft? #3032144
04/09/22 03:45 PM
04/09/22 03:45 PM
Andrewh Offline OP
Andrewh  Offline OP
I am not sure it is worth worrying about.
my car came out of chicago, so the driveshaft is pretty pitted.
but it doesn't have any significant horsepower to worry about twisting it or anything.
I am going through the driveline now, and noticed how rusted it looked.
1965 coronet with a 5.9 mag in it now. was originally a poly. original 273 gears.
do I just wait for it to fail if ever, or is it not even worth worrying about?
Re: how much rust is too much on a driveshaft? [Re: Andrewh] #3032183
04/09/22 05:57 PM
04/09/22 05:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Since you started worrying about it, now you know you’ll have to replace it. Law a nature
Re: how much rust is too much on a driveshaft? [Re: Andrewh] #3032189
04/09/22 06:16 PM
04/09/22 06:16 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
The driveshafts were not painted from the factory so they all rusted. They are pretty thick metal. Are you taking it down to replace the universal joints? If you are then I would clean the driveshaft as much as possible and coat it with a good rust inhibitor. Most of the driveshafts I have seen on the older cars are rusted and pitted.
Re: how much rust is too much on a driveshaft? [Re: 57Fury440] #3032193
04/09/22 07:23 PM
04/09/22 07:23 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
2x
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: how much rust is too much on a driveshaft? [Re: BigDaddy440] #3032198
04/09/22 08:00 PM
04/09/22 08:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Spray it down with ospho. I kills rust and is cheap at the hardware store. https://www.acehardware.com/departm...ng-and-disinfectants/rust-removers/13867
Re: how much rust is too much on a driveshaft? [Re: stumpy] #3032210
04/09/22 09:18 PM
04/09/22 09:18 PM
Andrewh Offline OP
Andrewh  Offline OP
yeah, was pulling it to put in new u-joints.
I guess I will try that ospho stuff, my local ace has it for 16 bucks.
thanks.
Re: how much rust is too much on a driveshaft? [Re: Andrewh] #3032211
04/09/22 09:22 PM
04/09/22 09:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
So for an accurate opinion we need to see how much rust you are talking about, Pictures always help.
Re: how much rust is too much on a driveshaft? [Re: Andrewh] #3032213
04/09/22 09:26 PM
04/09/22 09:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's the kind of thing that for me turns into a restoration laugh2 !
Well, used to...nowadays the cost of paint & materials would probably preclude that...
My 1st road Runner restoration started out with rear seat upholstery, and 1 cyl with weak compression.
But for a regular-power street car, I'd try not to let it bug me if it's not pitted too deeply.
Or, get another one or have one made...
Re: how much rust is too much on a driveshaft? [Re: 57Fury440] #3032215
04/09/22 09:33 PM
04/09/22 09:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Shafts were not always painted. I would not want anyone touching my unpainted shaft.
Re: how much rust is too much on a driveshaft? [Re: NITROUSN] #3032218
04/09/22 09:41 PM
04/09/22 09:41 PM
Andrewh Offline OP
Andrewh  Offline OP
I was going to but didn't get a camera out that day.
can't take it down for another week. Will post pics if I see anything more questionable.
Re: how much rust is too much on a driveshaft? [Re: topside] #3032227
04/09/22 10:15 PM
04/09/22 10:15 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Originally Posted by topside
........Or, get another one or have one made...
^^^This is where my head is. Fortunately there are still folks that specialize in drive shafts.
Re: how much rust is too much on a driveshaft? [Re: Fat_Mike] #3032231
04/09/22 10:48 PM
04/09/22 10:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree Order a new Strange Engineering shaft from Doctordiff and put your mind at ease twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: how much rust is too much on a driveshaft? [Re: Fat_Mike] #3032236
04/09/22 10:59 PM
04/09/22 10:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I put this one in a PVC pipe with one end capped. Then I filled it with vinegar. After about 12 hours I took it out and hosed it off and scrubbed the thick areas with a wire brush. Then put it back in for another 12. I can't remember how long it took to completely derust it. I also did one with EvapoRust. The key is to pick a pipe ID that isn't much bigger then the driveshaft OD. That way it takes less liquid to fill the pipe. If you try this method, you'll probably have to weight down the driveshaft so it doesn't float to the top. I used a brick to keep the driveshaft submerged.
Here it is all cleaned up next the the original driveshaft from my Dart. I'm planning on having this one cut down to fit since I replaced the 7-1/4 with an 8-3/4.
Re: how much rust is too much on a driveshaft? [Re: cudaman1969] #3032349
04/10/22 02:35 PM
04/10/22 02:35 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
haha This is what always happens to me...
Re: how much rust is too much on a driveshaft? [Re: burdar] #3032366
04/10/22 03:43 PM
04/10/22 03:43 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Vinegar and add some Lemi-Shine. By the soap stuff st any food store, Wal-Mart etc.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: how much rust is too much on a driveshaft? [Re: 340SIX] #3032369
04/10/22 03:49 PM
04/10/22 03:49 PM
Andrewh Offline OP
Andrewh  Offline OP
that is pretty amazing clean up.
