Re: how much rust is too much on a driveshaft?
[Re: 57Fury440]
#3032193
04/09/22 07:23 PM
04/09/22 07:23 PM
Posts: 707 California
BigDaddy440
California
The driveshafts were not painted from the factory so they all rusted. They are pretty thick metal. Are you taking it down to replace the universal joints? If you are then I would clean the driveshaft as much as possible and coat it with a good rust inhibitor. Most of the driveshafts I have seen on the older cars are rusted and pitted. 2x
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: Andrewh]
#3032211
04/09/22 09:22 PM
04/09/22 09:22 PM
Posts: 18,421 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I am not sure it is worth worrying about. my car came out of chicago, so the driveshaft is pretty pitted. but it doesn't have any significant horsepower to worry about twisting it or anything. I am going through the driveline now, and noticed how rusted it looked.
1965 coronet with a 5.9 mag in it now. was originally a poly. original 273 gears. do I just wait for it to fail if ever, or is it not even worth worrying about? So for an accurate opinion we need to see how much rust you are talking about, Pictures always help.
[Re: Andrewh]
#3032213
04/09/22 09:26 PM
04/09/22 09:26 PM
Posts: 20,787 A collage of whims
topside
A collage of whims
That's the kind of thing that for me turns into a restoration ! Well, used to...nowadays the cost of paint & materials would probably preclude that... My 1st road Runner restoration started out with rear seat upholstery, and 1 cyl with weak compression. But for a regular-power street car, I'd try not to let it bug me if it's not pitted too deeply. Or, get another one or have one made...
[Re: 57Fury440]
#3032215
04/09/22 09:33 PM
04/09/22 09:33 PM
NITROUSN
The driveshafts were not painted from the factory so they all rusted. They are pretty thick metal. Are you taking it down to replace the universal joints? If you are then I would clean the driveshaft as much as possible and coat it with a good rust inhibitor. Most of the driveshafts I have seen on the older cars are rusted and pitted. Shafts were not always painted. I would not want anyone touching my unpainted shaft.
[Re: topside]
#3032227
04/09/22 10:15 PM
04/09/22 10:15 PM
Posts: 3,062 N.W. Florida
Fat_Mike
N.W. Florida
........Or, get another one or have one made... ^^^This is where my head is. Fortunately there are still folks that specialize in drive shafts.
[Re: Fat_Mike]
#3032231
04/09/22 10:48 PM
04/09/22 10:48 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
........Or, get another one or have one made... ^^^This is where my head is. Fortunately there are still folks that specialize in drive shafts. Order a new Strange Engineering shaft from Doctordiff and put your mind at ease Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
