Re: Need Inexpensive Tires...Anyone Hear About Sailun?
[Re: Powerflow]
#3031851
04/08/22 01:28 PM
04/08/22 01:28 PM
Posts: 5,460 Michigan
oldjonny
Don't argue with me.
I think they are made by Krispy Kreme...but the standard Krispy Kreme donut would last longer.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#3031854
04/08/22 01:37 PM
04/08/22 01:37 PM
Posts: 1,384 Az
69hemibeep
Az
Due to supply chain problems I had to put them on my motor home, I got the last 6 tires in the Phoenix area at the time in that size.. That said all I know thus far is they balanced ok and they seam to be round LOL
1969 Hemi Roadrunner 2nd owner
[Re: moparjim79]
#3031894
04/08/22 04:01 PM
04/08/22 04:01 PM
Posts: 1,295 New Jersey
Powerflow
New Jersey
Whats the cost for a set, and whats the tire size? The size is P215-60R16 and I was quoted $120.00 each including mounting, balancing, and disposal. The least expensive Cooper (from the same tire shop) was $145.00 each.
[Re: Powerflow]
#3031897
04/08/22 04:21 PM
04/08/22 04:21 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
At Work We have had the same life out of cheap Chinese tires for one ton vans and even some big trucks as we have had with super expensive tires.
68 Barracuda Formula S 340
[Re: Powerflow]
#3031916
04/08/22 05:01 PM
04/08/22 05:01 PM
Posts: 4,945 WI
Dcuda69
WI
Whats the cost for a set, and whats the tire size? The size is P215-60R16 and I was quoted $120.00 each including mounting, balancing, and disposal. The least expensive Cooper (from the same tire shop) was $145.00 each. I'd spend the extra $100 for the Coopers but that's just me. Good luck!
[Re: Dcuda69]
#3031924
04/08/22 05:26 PM
04/08/22 05:26 PM
Posts: 1,407 Central Pa
moparjim79
Central Pa
Whats the cost for a set, and whats the tire size? The size is P215-60R16 and I was quoted $120.00 each including mounting, balancing, and disposal. The least expensive Cooper (from the same tire shop) was $145.00 each. I'd spend the extra $100 for the Coopers but that's just me. Good luck! Not a huge Cooper pooper fan, but I would have to agree
[Re: Powerflow]
#3031994
04/08/22 09:29 PM
04/08/22 09:29 PM
Posts: 12,090 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The late model wrecking yards around here have nice sets of 4 for $200 +/-. Sometimes basically new take-offs. IF you have someone that can mount and balance them.
Master, again and still
[Re: DaveRS23]
#3032023
04/09/22 12:29 AM
04/09/22 12:29 AM
Posts: 10,214 Someplace you aren't
SomeCarGuy
https://www.tirerack.com/tires/TireSearchResults.jsp?filtering=true&width=215%2F&ratio=60&diameter=16#allTitle
Has been about 100-120 bucks around here to get a set mounted. Who knows with inflation or living in the NE.
I want my fair share
[Re: SomeCarGuy]
#3032027
04/09/22 02:18 AM
04/09/22 02:18 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Plenty of used tires out there too...
China is the enemy.
