Re: Uconnect in Durango question
[Re: 3hundred]
#3030872
04/05/22 10:56 AM
04/05/22 10:56 AM
Posts: 3,384 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I think the easiest thing is to just keep the phone bluetooth turned off if you don't want to use it? Yep this is what I do.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Sniper]
#3031143
04/06/22 09:06 AM
04/06/22 09:06 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
I'd forgotten, he's an apple guy. Apple deleted the 3.5mm audio plug (2016?) long ago, I don't think the USB port will recognize the phone as a media player. The 2017 and later _might_ recognize it? Or it may just go full CarPlay boogie? What you can try, go into phone settings, (don't have the D here, but from foggy memory), delete the phone but keep the paired audio device. I really don't know if that will work, never tried it.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3031150
04/06/22 09:27 AM
04/06/22 09:27 AM
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I'd forgotten, he's an apple guy. Apple deleted the 3.5mm audio plug (2016?) long ago, I don't think the USB port will recognize the phone as a media player. The 2017 and later _might_ recognize it? Or it may just go full CarPlay boogie? What you can try, go into phone settings, (don't have the D here, but from foggy memory), delete the phone but keep the paired audio device. I really don't know if that will work, never tried it. I have an apple and I simply ordered an adapter (dongle?) for a few bucks and leave it attached to the end of the aux cord. I listen to my podcasts every day that way and to me its easier than messing with the bluetooth.
[Re: 3hundred]
#3031154
04/06/22 09:38 AM
04/06/22 09:38 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I'd forgotten, he's an apple guy. Apple deleted the 3.5mm audio plug (2016?) long ago, I don't think the USB port will recognize the phone as a media player. The 2017 and later _might_ recognize it? Or it may just go full CarPlay boogie? What you can try, go into phone settings, (don't have the D here, but from foggy memory), delete the phone but keep the paired audio device. I really don't know if that will work, never tried it. It works just the same as before, no change in functionality just the change in the plug style.
68 Barracuda Formula S 340
[Re: wingman]
#3031159
04/06/22 10:00 AM
04/06/22 10:00 AM
3hundred
Colleyville
Thank you, I'll show it to the wife when she gets home, I recall her carping about not being able to use her ear buds when she got the newer phone.
[Re: Bad340fish]
#3031334
04/06/22 05:28 PM
04/06/22 05:28 PM
Posts: 6,272 nowhere
Sniper
nowhere
I'd forgotten, he's an apple guy. Apple deleted the 3.5mm audio plug (2016?) long ago, I don't think the USB port will recognize the phone as a media player. The 2017 and later _might_ recognize it? Or it may just go full CarPlay boogie? What you can try, go into phone settings, (don't have the D here, but from foggy memory), delete the phone but keep the paired audio device. I really don't know if that will work, never tried it. It works just the same as before, no change in functionality just the change in the plug style. You are functionally unable to use a normal head phone set with it. You need the extra cost adapter mentioned, I have one. That adapter will not let you use a headphone/mic combo with a 3.5mm plug either. At least the one I have won't. You can listen, but no one can heard you speak. But since only my work phone is an Apple I don't care, I expensed out a new Apple specific set, if I had to buy one for myself I would be PO'd.
[Re: 3hundred]
#3031800
04/08/22 10:36 AM
04/08/22 10:36 AM
3hundred
Colleyville
I was wrong, the option is disconnect, not delete. You'll have to repeat it every start up. No way I know of to keep it from connecting as a phone as long as bluetooth is turned on, sorry.
