Am I nuts ? #3030678
04/04/22 06:19 PM
04/04/22 06:19 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Couldn't just have Dzus on a old school racecar. Got to have pins. But the plates with rivets just don't do the carbon hood justice. My friend Dave (home made hood and scoop) and Ted ( blocking and paint) worked to hard to make a race piece look way better than it should. So my friend Paul whipped up some nice aluminum plates that keep most of the pin up and away keeping scratches to a minimum. Couldnt have built this car without my buddies. Problem is the hood curves where the front pins come thru. The solution? Bend them in the press. Then stick sandpaper to the original hood and sand in the contour. They are thin and hard to hold. Made a tool out of a bolt. Took a litle while but now the fit is really good. They will be held on with some ultra stick two faced tape. Guess I better spring for some new pins. Yes I'm a detail nut.
Doug
Re: Am I nuts ? [Re: dvw] #3030680
04/04/22 06:30 PM
04/04/22 06:30 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
So cool! I've followed this car since you started building it. One of my favorite Mopars!
'63 Dodge 330
11.19 @ 121 mph
Re: Am I nuts ? [Re: dvw] #3030697
04/04/22 07:34 PM
04/04/22 07:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You’ve heard the old saying, “the devil is in the details”. It looks great, like the rest of the car.
Re: Am I nuts ? [Re: justinp61] #3030700
04/04/22 07:50 PM
04/04/22 07:50 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Very Impressive Doug wish I had your talents!
One of my favorite cars
Re: Am I nuts ? [Re: justinp61] #3030701
04/04/22 07:53 PM
04/04/22 07:53 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Sweet pieces. Nicely done.
Re: Am I nuts ? [Re: dvw] #3030702
04/04/22 07:54 PM
04/04/22 07:54 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
That's what separates the men from the boys. That's cool to see how you did that and the results.
Re: Am I nuts ? [Re: Hot 340] #3030703
04/04/22 08:10 PM
04/04/22 08:10 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yes, you're nuts - and that's a compliment.
I LOVE your car, and the thought and details that went into it.
Re: Am I nuts ? [Re: topside] #3030714
04/04/22 08:30 PM
04/04/22 08:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Simply fabulous!
I like everything about what you and your buddies did to make that nice.
Re: Am I nuts ? [Re: 440Jim] #3030715
04/04/22 08:31 PM
04/04/22 08:31 PM
Chesterfield Twp. Mi.
John Burdine Offline
Doug, how many pins do you have total?
Re: Am I nuts ? [Re: John Burdine] #3030716
04/04/22 08:36 PM
04/04/22 08:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I could use a pair of those for when we redo ole blue..Putting a new cage in now.
Re: Am I nuts ? [Re: Al_Alguire] #3030718
04/04/22 08:40 PM
04/04/22 08:40 PM
gregsdart Offline
gregsdart  Offline
Beautiful work, Doug! I wish i had that much talent and Patience.
Re: Am I nuts ? [Re: dvw] #3030766
04/04/22 10:43 PM
04/04/22 10:43 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Yes ---- yes you are nuts!!!
But thats ok I still like ya ---- up
Re: Am I nuts ? [Re: John Burdine] #3030768
04/04/22 10:45 PM
04/04/22 10:45 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
4 total. Works good though over the years it's bent the pins a bit. Not the body portion but the retainer. Amazing how much uplift the scoop develops. This thing is not very aerodynamic.
Doug
Re: Am I nuts ? [Re: dvw] #3030788
04/04/22 11:54 PM
04/04/22 11:54 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
No Doug, you are not nuts. You simply understand that the devil is in the details. Thank goodness we have craftsmen like you to push the envelope on what a HotRod can be. I aspire to develop my skills to levels I can’t currently attain, and posts like this are inspiring. Hopefully someday I can impress myself with my own work. Until then, thanks for showing the way.
Re: Am I nuts ? [Re: dvw] #3030805
04/05/22 04:39 AM
04/05/22 04:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Nice! The paint looks great too. What color is that?
Re: Am I nuts ? [Re: 451Mopar] #3030818
04/05/22 07:06 AM
04/05/22 07:06 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It's GM Sunburst Orange code 802. The credit for the beautiful body and paint goes to my longtime friend Ted Smith. He's done more than a few out of his garage. They always turn out like this.
Doug
Re: Am I nuts ? [Re: dvw] #3030821
04/05/22 07:46 AM
04/05/22 07:46 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
car is unreal....most important thing is patience... great job bumper to bumper on that car up
....BAD A$$ STREET CAR.....
Re: Am I nuts ? [Re: n20mstr] #3030901
04/05/22 12:29 PM
04/05/22 12:29 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I feel the same as I didn't want dzus visible on my hood either. I run the factory hood pin and latch assembly. However, my hood is still bolt on.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Am I nuts ? [Re: 6PKRTSE] #3030904
04/05/22 12:39 PM
04/05/22 12:39 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
A lot to be said for a bolt on. Dizusters 62 is sneaky. The pins screw into the bottom of the hood. The clips go in thru small slots in the grille.
Doug
Re: Am I nuts ? [Re: dvw] #3031293
04/06/22 03:17 PM
04/06/22 03:17 PM
moparx Offline
moparx  Offline
just another FABULOUS detail on your car ! bow
beer
