Re: Block Repair Help
[Re: 3_RTs]
#3030488
04/04/22 08:30 AM
04/04/22 08:30 AM
Posts: 703 WV
Little Detroit
WV
make sure you find someone with a great reputation for welding cast Iron , to do it correctly it needs to be heated in an oven to a certain temperature and held at that temperature until entire block has reached temperature evenly ,,has to be welded at that temp and heat kept on even keel until repairs are completed , then then cooled in increments over a period of time. saw it done a few times when I was young evidently my memory is as good on exact details as it use to be. Don't just look for car guys for this type of repairs , if possible look to find European or Russian immigrant professional welders as cast iron is a cheaply produced metal widely used in the east and they experts in cast iron repairs. Indy Cylinder head use to do it years ago.
[Re: 3_RTs]
#3030650
04/04/22 04:04 PM
04/04/22 04:04 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
Thanks, Cudaman. I will see if I can make contact with him. If you figure it out, please send any info.
The one I said has all those capabilities mentioned below, using ovens and cooling a little bit over days. Just texted him for his number, got back fast! 708-749-3420
[Re: 3_RTs]
#3030773
04/04/22 11:04 PM
04/04/22 11:04 PM
Posts: 1,546 Mattituck NY.
FJ6AAR
Mattituck NY.
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
[Re: FJ6AAR]
#3030801
04/05/22 01:19 AM
04/05/22 01:19 AM
Posts: 3,069 Michigan
A727Tflite
X
[Re: A727Tflite]
#3030834
04/05/22 09:04 AM
04/05/22 09:04 AM
FJ6AAR
Mattituck NY.
[Re: FJ6AAR]
#3030842
04/05/22 09:31 AM
04/05/22 09:31 AM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Have those repairs been welded or brazed? Just looking at the bead color.
[Re: 6PakBee]
#3030850
04/05/22 09:53 AM
04/05/22 09:53 AM
FJ6AAR
Mattituck NY.
[Re: Moparite]
#3033687
04/14/22 10:45 PM
04/14/22 10:45 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
This is brazed! If it where my block make sure it is heated and properly stick welded using a strong alloy welding rod. I agree, they are both absolutely brazed.
[Re: B1MAXX]
#3034096
04/16/22 12:11 PM
04/16/22 12:11 PM
Posts: 971 rust belt
Moparite
rust belt
I think its properties are stronger than cast iron. As per google: Filler Metal and Flux for Braze Welding The filler metal used for most braze welding is a copper alloy containing roughly 60% copper, 40% zinc, and small amounts of tin, iron, manganese, and silicon. Not as strong as cast iron. It may be "acceptable" but if i where trying the save a rare hemi block i wouldn't be brazing it.
