Re: Block Repair Help
[Re: 3_RTs]
#3034262
04/16/22 10:15 PM
04/16/22 10:15 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Years ago one of my Dad's big diesel engines had a crack in the block. He bought some special certanium alloy welding rods and his friend who was a welder sparked it up for him. Never had an issue with the repair.
I'll mention one other thing be sure to magnaflux to look for cracks. Drill out the end of any crack prior to repair to avoid chasing it and making it worse.
Good luck.
[Re: B1MAXX]
#3034542
04/17/22 09:52 PM
04/17/22 09:52 PM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
agree , but Brazing is an acceptable way to repair cast iron.I think its properties are stronger than cast iron. Yes brazing is acceptable, the repair on the skirt by the oil pan rail will most likely only fail if smacked by a connecting rod again but so would the rest of the block. But brazing that main bearing support would worry me, especially if a racing engine.
[Re: GODSCOUNTRY340]
#3034649
04/18/22 12:31 PM
04/18/22 12:31 PM
Posts: 1,968 Apollo, PA.
B1MAXX
Apollo, PA.
agree , but Brazing is an acceptable way to repair cast iron.I think its properties are stronger than cast iron. Yes brazing is acceptable, the repair on the skirt by the oil pan rail will most likely only fail if smacked by a connecting rod again but so would the rest of the block. But brazing that main bearing support would worry me, especially if a racing engine. If the brazing rod has a higher strength than cast iron, why? I would think that it is the strongest part of the block. Just wondering why. Not trying to argue.
[Re: R/T1968R/T]
#3034699
04/18/22 02:40 PM
04/18/22 02:40 PM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
Fixed this block with Certanium rods. Not sure if they are still manufactured. I’d like to purchase some of those rods, any ideas on where?
[Re: B1MAXX]
#3034777
04/18/22 05:47 PM
04/18/22 05:47 PM
GODSCOUNTRY340
agree , but Brazing is an acceptable way to repair cast iron.I think its properties are stronger than cast iron. Yes brazing is acceptable, the repair on the skirt by the oil pan rail will most likely only fail if smacked by a connecting rod again but so would the rest of the block. But brazing that main bearing support would worry me, especially if a racing engine. If the brazing rod has a higher strength than cast iron, why? I would think that it is the strongest part of the block. Just wondering why. Not trying to argue. It would all depend on the brazing rod used for the repair. The Harris-Welco 017FC60 rod is 70% nickel and an excellent cast iron brazing rod. If the customer was sure the welder (brazer) used that rod it would be stronger than the cast iron and hold up well.
[Re: cudaman1969]
#3035955
04/22/22 10:51 AM
04/22/22 10:51 AM
Posts: 3,021 NY
B1duster
NY
Fixed this block with Certanium rods. Not sure if they are still manufactured. I’d like to purchase some of those rods, any ideas on where? Found this on a welding site - sounds like cold weld to me “If you can find it, Certanium 889SP is magic for cast iron. It needs no preheat, is machinable, AC/DC, material doesn't have to be real clean, just a good V prep. Do little, skip, do a llittle more, skip, etc. If you can't hold your hand on it, quit till you can, and go back at it. You won't be disappointed.“
[Re: B1duster]
#3036161
04/22/22 10:14 PM
04/22/22 10:14 PM
cudaman1969
fredericksburg,va
Fixed this block with Certanium rods. Not sure if they are still manufactured. I’d like to purchase some of those rods, any ideas on where? Found this on a welding site - sounds like cold weld to me “If you can find it, Certanium 889SP is magic for cast iron. It needs no preheat, is machinable, AC/DC, material doesn't have to be real clean, just a good V prep. Do little, skip, do a llittle more, skip, etc. If you can't hold your hand on it, quit till you can, and go back at it. You won't be disappointed.“ Sent an email to the company asking for a dealer close so I can buy and try some.
