Re: Block Repair Help [Re: 3_RTs] #3034262
04/16/22 10:15 PM
04/16/22 10:15 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Years ago one of my Dad's big diesel engines had a crack in the block. He bought some special certanium alloy welding rods and his friend who was a welder sparked it up for him. Never had an issue with the repair.
I'll mention one other thing be sure to magnaflux to look for cracks. Drill out the end of any crack prior to repair to avoid chasing it and making it worse.
Good luck.
Re: Block Repair Help [Re: Cab_Burge] #3034339
04/17/22 10:32 AM
04/17/22 10:32 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I was just going by the fact that the nickel cast welding rod is rated at 55,000 tensile strength, vs the brazing rod rated at 65,000
Re: Block Repair Help [Re: B1MAXX] #3034542
04/17/22 09:52 PM
04/17/22 09:52 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Originally Posted by B1MAXX
agree , but Brazing is an acceptable way to repair cast iron.I think its properties are stronger than cast iron.
Yes brazing is acceptable, the repair on the skirt by the oil pan rail will most likely only fail if smacked by a connecting rod again but so would the rest of the block. But brazing that main bearing support would worry me, especially if a racing engine.
Re: Block Repair Help [Re: mgoblue9798] #3034630
04/18/22 11:22 AM
04/18/22 11:22 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Fixed this block with Certanium rods. Not sure if they are still manufactured.
Re: Block Repair Help [Re: GODSCOUNTRY340] #3034649
04/18/22 12:31 PM
04/18/22 12:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
If the brazing rod has a higher strength than cast iron, why? I would think that it is the strongest part of the block. Just wondering why. Not trying to argue.
Re: Block Repair Help [Re: R/T1968R/T] #3034699
04/18/22 02:40 PM
04/18/22 02:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’d like to purchase some of those rods, any ideas on where?
Re: Block Repair Help [Re: B1MAXX] #3034777
04/18/22 05:47 PM
04/18/22 05:47 PM
It would all depend on the brazing rod used for the repair. The Harris-Welco 017FC60 rod is 70% nickel and an excellent cast iron brazing rod. If the customer was sure the welder (brazer) used that rod it would be stronger than the cast iron and hold up well.
Re: Block Repair Help [Re: cudaman1969] #3034817
04/18/22 08:20 PM
04/18/22 08:20 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
You can try Lawson https://www.lawsonproducts.com/Certanium/889-Cast-Iron-Stick-Rod-Electrode-532/P12006.lp There are other brands that are high nickel content. The certanium seem to flow real well, but pricey. Good deal on ebay for nickel rods https://www.ebay.com/itm/294318845754?hash=item4486c52f3a:g:GCEAAOSwxZRhDY2H
Re: Block Repair Help [Re: R/T1968R/T] #3034843
04/18/22 09:01 PM
04/18/22 09:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yep, looked them up. A few have them forsale. Kinda wondering if these are what Muggy Weld is selling?
Re: Block Repair Help [Re: 3_RTs] #3035891
04/22/22 06:02 AM
04/22/22 06:02 AM
NY
B1duster Offline
B1duster  Offline
NY
Ok I got a story for you. About 25 years ago I needed a Mega block repaired that had a small window and pan rail damaged.
I was told to go see Charlie in Middletown, NY. He was an older guy who did repairs on all kinds of engines and machinery.
He prepped the block and “cold welded” half inch at a time with nickel rods. He then ground smooth , dressed and stress relieved it with a hammer and punches...When he was finished you couldn’t see the repair.
The story was that in his youth he designed and built the machine that polished the lens/mirror on the Hubble telescope for NASA.
Re: Block Repair Help [Re: B1duster] #3035910
04/22/22 08:36 AM
04/22/22 08:36 AM
VA
dragon slayer Offline
VA
Anyone have experience with a block that the crack has gone into the lifter bore? How much thickness between water jacket and lifter bore oil galley on RB/hemi blocks?
Re: Block Repair Help [Re: cudaman1969] #3035955
04/22/22 10:51 AM
04/22/22 10:51 AM
NY
B1duster Offline
B1duster  Offline
NY
Found this on a welding site - sounds like cold weld to me
“If you can find it, Certanium 889SP is magic for cast iron. It needs no preheat, is machinable, AC/DC, material doesn't have to be real clean, just a good V prep. Do little, skip, do a llittle more, skip, etc. If you can't hold your hand on it, quit till you can, and go back at it. You won't be disappointed.“
Re: Block Repair Help [Re: B1duster] #3036161
04/22/22 10:14 PM
04/22/22 10:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sent an email to the company asking for a dealer close so I can buy and try some.
