Hitting the track! What's it gonna run? #3030086
04/02/22 09:01 PM
04/02/22 09:01 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm taking the pig to the track. What's it gonna run?
5100 lbs
2.65 open rear gear
5 speed auto
275/35-20 Michelin Pilot Sport 4S
It has this thing with torque...
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030106
04/02/22 10:26 PM
04/02/22 10:26 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
You need a couple Twister decals on there with that torque! No idea what that will run,but are you planning on a lower rear gear at some point since you have the 5-speed?
Re: Hitting the track! What's it gonna run? [Re: RTSrunner] #3030116
04/02/22 11:33 PM
04/02/22 11:33 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
No. This is a Mercedes CL65. I'm just playing with it, not turning it into a drag car.
However, I do have a limited slip diff on order. It should cut down on the wheel spin at 50 mph.
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030180
04/03/22 10:24 AM
04/03/22 10:24 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I know this thing is no drag racer so I expected one of those slow ET high speed mismatches. Ready to see a 12.4 but hoping for an 11.9 I dropped the tire pressure to 30 psi (performance radial, not a drag tire) and got in line. The track was prepped fairly well so I brought the revs up to 1200 and put it to the mat on green. It left fairly well like that.
After a couple fairly good hooks I tried leaning in the converter at 1800 rpm but it annihilated the tires and killed the pass.
I knew the holeshot would be the hard part so focused on that, not chopping down the tree.
She's a big girl but will lift her skirt and run.
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030183
04/03/22 10:33 AM
04/03/22 10:33 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Pretty dang consistent beast ya got there, given it was a test session.
I'm actually surprised at the weight, so 11.80s is impressive IMO.
Re: Hitting the track! What's it gonna run? [Re: topside] #3030200
04/03/22 11:26 AM
04/03/22 11:26 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I expected a bit more weight. They're supposedly 4940 lbs. I had driven 30 miles on a full tank. Then, you've got to account for my bloated 235 lb carcass.
The wheelspin run had a 2.1 short time and a 13.06 @ 118.
On my only other run I tried a bit more RPM on the converter and pedaling the car. It rewarded me with a 1.95 60' and 11.95 @ 119.
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030222
04/03/22 12:34 PM
04/03/22 12:34 PM
That car is doing well bow up
There are very few old muscle cars, let alone a new car, that will run those times bow
Have fun wrench
Re: Hitting the track! What's it gonna run? [Re: feets] #3030257
04/03/22 01:51 PM
04/03/22 01:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I didn't have a clue what it would run, but I bet it's a hoot on the street!
Re: Hitting the track! What's it gonna run? [Re: Cab_Burge] #3030284
04/03/22 03:10 PM
04/03/22 03:10 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Have fun wrench
I was likely the only one getting a massage while watching Full Metal Jacket in the staging lanes. 😁
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030328
04/03/22 04:43 PM
04/03/22 04:43 PM
AndyF Online content
AndyF  Online Content
High 11's is really hauling balls for a full boogie luxury car. That is faster than any of the "classic" muscle cars and is on par with many of the newer muscle/super cars.
Re: Hitting the track! What's it gonna run? [Re: AndyF] #3030333
04/03/22 04:58 PM
04/03/22 04:58 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
No sh!t; I don't even know what feets' car looks like, but I know it runs hard with that sort of ET slip eek
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hitting the track! What's it gonna run? [Re: Brad_Haak] #3030409
04/03/22 08:39 PM
04/03/22 08:39 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It'll be purty again once I get rid of the yellow on the calipers.
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: justinp61] #3030418
04/03/22 09:04 PM
04/03/22 09:04 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
It can be a bit frustrating, actually. It is traction limited under 55 mph. The right rear breaks loose, gers grabbed by ESP, then the left rear spins. Once the left gets a brake bump the right turns again. That irritates the ESP so it dumps boost and upshifts.
ESP can be turned down but not off.
Now, giving it a squirt of boost on the highway is entertaining. I have the Torque Pro app and tried out the 60-130 mph timer.
To get a proper time, you roll in at 50 mph so you're at full gallop when the timer starts. One run broke traction and had ESP interference. The other run went properly. On a closed course in Mexico, of course.
- Stu Harmon
Re: Hitting the track! What's it gonna run? [Re: feets] #3030446
04/03/22 10:57 PM
04/03/22 10:57 PM
Originally Posted by feets
[quote=justinp61]. The other run went properly. On a closed course in Mexico, of course.
haha up devil
Re: Hitting the track! What's it gonna run? [Re: Cab_Burge] #3030449
04/03/22 11:27 PM
04/03/22 11:27 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
That thing really hauls the mail!
Re: Hitting the track! What's it gonna run? [Re: feets] #3030531
04/04/22 11:08 AM
04/04/22 11:08 AM
moparx Online content
moparx  Online Content
as those calipers are quite visible, what color would be best, or what color do you have in mind ?
beer
Re: Hitting the track! What's it gonna run? [Re: moparx] #3030619
04/04/22 03:05 PM
04/04/22 03:05 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
beer
Red is played out. That front double caliper setup can is really visible so it can make or break the car. Pun intended?
I'm leaning towards the bronze color used on ceramic brake cars with black AMG logos.
Something like this:
- Stu Harmon
