Re: mr gasket high flow thermostat????
[Re: Nick Mineau]
#302663
04/29/09 12:09 AM
04/29/09 12:09 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
does the mr gasket high flow thermostat really flow more than a stocker?
Seams a lot of stuff from Mr. Gasket is made overseas. I used a Milodon stat. I guess it could be made overseas too, but it seams to work really well. Opens right at 180.
Yes they do flow more than stock and they are balanced so they work better at high rpms than the stock ones.
[Re: torkrules]
#302666
04/29/09 12:16 AM
04/29/09 12:16 AM
Posts: 350 CT USA
Nick Mineau
CT USA
thanks i was just wondering because the discreption didnt say anything about high flow just high performance.
[Re: ademon]
#302671
04/29/09 06:55 PM
04/29/09 06:55 PM
Posts: 34 Highland, CA
Mosin
Highland, CA
Is there a part number for the Milodon skirted 180 deg. thermostat? Or did I misinterpret and the Milodon is not skirted? Not asking out of laziness... I've looked for other brands besides Mr. G but struck out. Thanks!
[Re: Nick Mineau]
#302673
04/29/09 07:49 PM
04/29/09 07:49 PM
Posts: 26,544 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Mr.Gasket high-flow is a repackaged Robertshaw.
[Re: Crizila]
#302675
04/29/09 08:55 PM
04/29/09 08:55 PM
Posts: 7,664 IN
ahy
IN
I've run the Mr Gasket 180 stat without problem... around 3 years and 5k miles. I've heard of the QC problems but haven't experienced them.
What I was after was the "balance". I'm running a high volume pump with anti cavitation plate slightly overdriven. I wanted to make sure the very high flow at high RPM didn't move the stat plate. For $5 or $10 extra its cheap insurance.
Don't know why you would want to over-drive it? The restriction is still gonna be the stat, even with the hi volume unit. The last 5 purchases I have made with the Mr Gasket brand on the product - 3 ether didn't fit or were missing parts. Most recent ( a month ago )was a sb gasket set. It was missing one pan rail gasket.
I wasn't really worried about the restriction. I was worried about the fast stream of water hitting the plate on a conventional thermostat and overpowering the actuating mechanism making the stat non functional.
My setup wound up about 7% overdriven by pulley choice and avaialbility. The cooling system works great even at idle on a 95 deg day with AC on or blasts to 6000 RPM. I guess I could try to find some different pulley's and experiment with slower WP and fan speeds but its not high on my list of projects and I'd likley loose cooling performance at idle with the AC.
