Re: Ladder bars with leaf sping [Re: CMcAllister] #3026064
03/21/22 02:44 PM
03/21/22 02:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Never said leaf springs were a waste. I said leaf springs used with ladder bars was a waste. Why? They are more complicated, heavier, and more expensive than coil overs.
Doug
Re: Ladder bars with leaf sping [Re: dvw] #3026118
03/21/22 06:24 PM
03/21/22 06:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Pick a side and go with it (ladder bar with coil over, or leaf spring with Caltrac).
Leaf spring floaters can be heavy, the last car I had with them I converted over to Caltracs instead.
Alan Jones
Re: Ladder bars with leaf sping [Re: LA360] #3026236
03/21/22 11:20 PM
03/21/22 11:20 PM
florida dade
cesar perez Offline OP
florida dade
Caracas setup is very expensive compared to 4 link or ladder bar iam interested in building a nostalgic 70 71 prostock with 4 speed
Re: Ladder bars with leaf sping [Re: cesar perez] #3026252
03/22/22 12:24 AM
03/22/22 12:24 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
A 70-71 Pro Stock Challenger had a pinion snubber and leaf springs.
Re: Ladder bars with leaf sping [Re: CMcAllister] #3026263
03/22/22 03:09 AM
03/22/22 03:09 AM
How fast and quick did they run back thenwhistling grin
Re: Ladder bars with leaf sping [Re: Cab_Burge] #3026297
03/22/22 09:34 AM
03/22/22 09:34 AM
Minn
SportF Offline
SportF  Offline
Minn
If you are relying on a pinion snubber for traction on a race car you just haven't ripped out a sprague or u joint yet.
Re: Ladder bars with leaf sping [Re: Cab_Burge] #3026374
03/22/22 01:14 PM
03/22/22 01:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
9.50s @ mid 140s
Quote
I'm not recommending pinion snubbers for modern race cars.
He was talking about 4 links and ladders bars while talking about a period correct (I assume) early 70s Pro Stock car, I was just telling him what was correct for that era. I wouldn't recommend anything in common use in 1970 for use today.
Although some of the cheating tricks were clever.
Re: Ladder bars with leaf sping [Re: CMcAllister] #3026656
03/23/22 07:39 AM
03/23/22 07:39 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Leaf link. Sorry for the dark pics.
Re: Ladder bars with leaf sping [Re: fbs63] #3026764
03/23/22 01:32 PM
03/23/22 01:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Nice.
A person could take that idea a few steps further, borrowing a few ideas from the RMS rear suspension.
Replace the leaf spring with a lower link from the housing spring perch to the front spring mount. You could likely use the brackets you have there. Add an upper crossmember, shock mounts on the housing and some coilovers. Housing location device (lateral link would be easy) with the parallel 4 link. Or you could do a non-parellel design with different upper mounts.
We have done this in the past on OE floors & framerails restomod type deals with maybe the inner wheel tub moved in. Works well. And you get the advantages of a 4 link style suspension - which are more than just "more adjustable".
Re: Ladder bars with leaf sping [Re: CMcAllister] #3026997
03/24/22 08:47 AM
03/24/22 08:47 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice Bob! It's about time someone resurrected the idea. Is this something you did recently?
Re: Ladder bars with leaf sping [Re: HardcoreB] #3027291
03/25/22 07:10 AM
03/25/22 07:10 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Cmcallister: I have toyed with the same idea. I could run the car on leafs or coil-overs.
HardcoreB: Yes, on my current 63 Dodge.
