Re: Guess the Dyno Results - 572 CID B1 original heads
[Re: 440Jim]
#3025669
03/20/22 09:04 AM
03/20/22 09:04 AM
Posts: 4,457 Washington
madscientist
Washington
After supplying a BB Mopar bellhousing, 8-bolt manual transmission flywheel, starter, etc. the dyno shop that said they will test my engine called and said they can't do it. Their dyno mounting has several hole patterns (trans patterns) to bolt the dyno to the engine bellhousing; but none fit the Chrysler A833 manual transmission. A833 5.28" wide top holes 7.125" wide bottom holes 7.875" height from top to bottom holes I will go out to the shop today and look at mine. I’ll see if mine will take that pattern. I haven’t gotten my dyno up and running yet but it’s close. Waiting on some hardware and a couple of water pumps. Now that I think about it...it may not have the 833 pattern on it. I have a scatter shield and it has the 833 and GM pattern on it. I just can’t believe there isn’t an 833 pattern on it though.
[Re: 440Jim]
#3025732
03/20/22 12:47 PM
03/20/22 12:47 PM
Posts: 31,264 Oregon
AndyF
Here is another option, BB Mopar to Muncie bellhousing. You would want to verify the pattern that they have on the dyno but I would assume that Muncie would be one of the choices. https://www.holley.com/products/drivetrain/bellhousings/mopar/parts/RM-6078You can also redrill your existing bellhousing and/or weld a plate on it with the correct pattern. All depends on which way works out the easiest for you.
[Re: AndyF]
#3025733
03/20/22 12:48 PM
03/20/22 12:48 PM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For the typical SF situation, you also need a centering ring to locate the bell housing to the absorber. The Mopar bell housing also puts the engine farther forward, and has the crank farther away from the input shaft. In order to get the pilot of the shaft centered on the crank, you either need a longer than “standard” shaft, a spacer behind the shaft to move it closer to the crank, or an extension located at the back of the crank....... the latter of which is what we do here.
The bellhousing gets drilled to facilitate two of the lower absorber mounting holes, and we use bolts with nuts to secure it. We bought the correct centering ring from SF to locate the bellhousing.
None of it is hard........ but someone has to “want” to make it happen.
[Re: sasquatch]
#3025843
03/20/22 07:12 PM
03/20/22 07:12 PM
Posts: 16,941 NC
440Jim
NC
Jim Would a JW Ultra bell for a BB to glide and a wheel and adapter work????? Todd I thought about that. Then I looked at the JW bell on my PowerGlide. It uses the PG pump holes to mount to the transmission. So that pattern is certainly not on his old absorber attachment plate (not a transmission to bellhousing pattern). He will be returning my engine and parts Monday. His full time job is only 10 minutes from my house. The dyno is at his house. He agreed it can be done, but it will take modifying/making parts and he is not going to do that. He actually does mostly NASCAR cup engines. He has a "plate with torsion springs" for the small dia Cup clutch, as well as the "street clutch" plate that does fit on the flywheel I gave him. For other Moparts members, Both the bellhousing and flywheel were borrowed, so I can't let him modify them. He would need to buy his own to modify. He said he is not in a position to do that.
[Re: 440Jim]
#3025844
03/20/22 07:19 PM
03/20/22 07:19 PM
Posts: 730 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I know I am a long ways away, but if you could find someone that has a DTS/SF powermark there is no bellhousing needed.
Joe
Without Data, you’re just another guy with an opinion.
[Re: 440Jim]
#3025916
03/21/22 01:09 AM
03/21/22 01:09 AM
madscientist
Washington
After supplying a BB Mopar bellhousing, 8-bolt manual transmission flywheel, starter, etc. the dyno shop that said they will test my engine called and said they can't do it. Their dyno mounting has several hole patterns (trans patterns) to bolt the dyno to the engine bellhousing; but none fit the Chrysler A833 manual transmission. A833 5.28" wide top holes 7.125" wide bottom holes 7.875" height from top to bottom holes Yep, my dyno won’t take an 833 pattern either. I never noticed because any time I’ve taken my junk to the dyno I always took my scatter shield with me and we used that. It has the GM pattern on it. So I never even looked at my dyno. So now tomorrow I will be ordering a universal fit bell housing so I don’t have to screw around.
[Re: LA360]
#3025928
03/21/22 05:57 AM
03/21/22 05:57 AM
Posts: 1,858 NW Indiana
fbs63
NW Indiana
[Re: fast68plymouth]
#3025950
03/21/22 07:48 AM
03/21/22 07:48 AM
Posts: 4,281 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I have seen enough “strange looking” dyno sheets over the years to know they definitely don’t all spit out the same numbers.
The combo is pretty straight foward, and unless something is “wrong” with the motor, it’s going to make good power.
I feel that whatever the numbers are........ they could easily vary by over 50hp if the engine were tested on some different dyno services.
Just work on the tune up, get the best numbers you can....... and don’t get too excited about whatever the actual number is. Well said! Jim, sorry for your current difficulties!
[Re: HardcoreB]
#3025967
03/21/22 08:54 AM
03/21/22 08:54 AM
Posts: 1,398 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Jim - Sorry to hear that things didn't go as planned. Maybe I missed it, but do you have a Plan B?
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3025971
03/21/22 09:26 AM
03/21/22 09:26 AM
Posts: 16,941 NC
440Jim
NC
Jim - Sorry to hear that things didn't go as planned. Maybe I missed it, but do you have a Plan B? This was already plan "Z". Called lots of places the past couple months... With all the old Mopar racers and general car racing in North Carolina, I am amazed nobody is dyno testing Hemi engines anymore. Only if they built the engine.
[Re: 440Jim]
#3025986
03/21/22 09:51 AM
03/21/22 09:51 AM
fast68plymouth
So. Burlington, Vt.
I guess it’ll depend in part on how far you’re willing to drive.
Alan P has a Mopar friendly dyno in NJ, and there’s always Barton in Pa.
You could also call Todd Marsh and see about the shop he uses.
[Re: 440Jim]
#3025995
03/21/22 10:09 AM
03/21/22 10:09 AM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
Jim, there's an engine builder/machinist in Conway, SC, named Jesse Causey that has a dyno and I believe he has the ability to dyno a Mopar BB. Jesse is very good at what he does, but works a limited schedule nowadays. I have never dealt w/ him myself, but member here "ek3" has. Might be worth a shot to check w/ him if Todd Marsh can't hook you up.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3025999
03/21/22 10:17 AM
03/21/22 10:17 AM
Brad_Haak
Loudoun County, VA
Is coming back to MD too far? Burtonsville Performance Machine was OK w/ dyno-ing my engine before I decided to make the trip back to VT and have Dwayne handle it. And BPM does enough Stock Eliminator stuff I'd be shocked if they can't handle a G2 Hemi / 8-bolt crank deal. Edit: If BPM can do the job, it's 40 miles from me (1 hour + drive depending upon traffic) and you're welcome to crash here night before / night after to save on travel expenses. Anyway, just throwing that out there.
[Re: 440Jim]
#3026002
03/21/22 10:27 AM
03/21/22 10:27 AM
Posts: 75,326 A gulag near you.
JohnRR
A gulag near you.
After supplying a BB Mopar bellhousing, 8-bolt manual transmission flywheel, starter, etc. the dyno shop that said they will test my engine called and said they can't do it. Their dyno mounting has several hole patterns (trans patterns) to bolt the dyno to the engine bellhousing; but none fit the Chrysler A833 manual transmission. A833 5.28" wide top holes 7.125" wide bottom holes 7.875" height from top to bottom holes Jim if we lived closer I could lend you the Lakewood blowshield we used for the Enginemasters , I drilled the needed hole pattern in it so that wouldn't have been an issue. On that note if it would work I can ship it to you and pick it up on my way back from FL. late May , early June ?
Mainstream Media is the new Pravda
[Re: 440Jim]
#3026018
03/21/22 11:28 AM
03/21/22 11:28 AM
Posts: 10,155 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Jim, thankyou for sharing a great build,as well as help on my project. I am sort of lost on what power it will make, but i will hazard a guess of 980 hp at 7200 rpm, and 770 tq at 5600 rpm. What ever it comes out at, it will be a stout ride👍
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#3026026
03/21/22 11:53 AM
03/21/22 11:53 AM
Posts: 19,610 Las Vegas
Al_Alguire
Las Vegas
As said find a DTS/Superflowand there is no bell needed. For one requiring a bell use a BBM to PG adapter plate like sold by ATI and TCI and you should be golden. We have one here we use just for dyno stuff if we use a local shop that uses a bell set up. Not an insurmountable problem for sure. Finding someone with a smidgen of knowledge about BBM and dynos can be the hard part.
AS for power I can tell you my 4150 carb is about 20 HP down on my 540" B1. IMO a vacuum pump is not a "fancy"part these days and I belive is something any race engine needs and will benefit from. As for power compression ratio will kill some, I have made lots of power on unported intakes and seen very very little from ported ones, especially at 572". Id say you will be in the 915ish area if you can get it done.
