Chrysler Marine V-8s #302523
04/28/09 09:46 PM
04/28/09 09:46 PM
Fredericktown, PA 15333
maundmotorworks Offline OP
Stealth poster
Stealth poster
I picked up a Chrysler Marine 383/260HP engine today from the local wrecking yard. It's complete with carb, mounts, gearbox, water cooled exhaust, timing cover w/ tach drive (yes, that's correct). Anybody else on here have a Marine big block? Just curious...
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302524
04/28/09 09:51 PM
04/28/09 09:51 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had a marine 440 a while ago...still have the cast iron timing cover (no water pump provision) and cast aluminum oil pan with swinging pick up.
It was a reverse rotation...so tossed the crank out and just used the block basically for a fresh build
Re: Chrysler Marine V-8s [Re: OzHemi] #302525
04/28/09 09:57 PM
04/28/09 09:57 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
i got a 440,it has some neat parts inside.
steel crank
3 bolt purple cam
double roller set
oil pump drive holder downer thing
Re: Chrysler Marine V-8s [Re: OzHemi] #302526
04/28/09 09:57 PM
04/28/09 09:57 PM
Stealth poster
Stealth poster
Oz,
According to the tag, my engine is right hand rotation. I had been watching for this engine to come available for about 8 or 9 years now, and finally got it. I may be interested in your pan and cover for spares. I'm sure that there aren't too many of these engines floating around anymore, so I figured I'd grab it anyway and basically mothball it in the shop for a future project. The boat it was in was badly rotten, so they cut the engine out with a chainsaw. It's still bolted to pieces of the stringers of the boat. I got the complete engine with gearbox and prop shaft for $450, so I figured if nothing else, it's got to be worth that for parts especially since both exhaust manifolds are intact.
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302527
04/28/09 09:58 PM
04/28/09 09:58 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Just holler if you are interested....they are not light though, that's for sure!
(and sounds cool about cutting it out with a chainsaw! )
Re: Chrysler Marine V-8s [Re: OzHemi] #302528
04/28/09 10:00 PM
04/28/09 10:00 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Just to show what it looks like..
Re: Chrysler Marine V-8s [Re: OzHemi] #302529
04/28/09 10:02 PM
04/28/09 10:02 PM
Stealth poster
Stealth poster
Believe it or not, that's not the first engine I've removed with a chainsaw. I bought another engine from a rotten houseboat a few years back and did the same thing. A cut through the stringers and floor in front and rear of the engine and a cut down the length of each stringer, and whoa-la...out the engine comes cradle and all. Makes it easy to strap down and haul away too since the engine's still bolted to something...
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302530
04/28/09 10:03 PM
04/28/09 10:03 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Don't worry...I am good about cutting up boats with a saw too...
You probably missed my post a month ago about sawzalling a boat to fit into a container to send to Oz.
Re: Chrysler Marine V-8s [Re: OzHemi] #302531
04/28/09 10:04 PM
04/28/09 10:04 PM
Stealth poster
Stealth poster
Out of curiousity, how much for that stuff?
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302532
04/28/09 10:05 PM
04/28/09 10:05 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Swap you for a handfull of magic beans ?
I'll shoot you a PM
Re: Chrysler Marine V-8s [Re: OzHemi] #302533
04/28/09 10:10 PM
04/28/09 10:10 PM
Stealth poster
Stealth poster
Ok, sounds good...
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302534
04/28/09 10:33 PM
04/28/09 10:33 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I have a marine block in my '56 ..it was right rotation ..but I put my original crank in and everything else from the 1968 440...just used the block...had very low time on the motor and the bores were perfect ...still got the heads and intake and AFB .ecu..and some other stuff ...steel crank ..but have to have the rear maim nearling ground off.. Oh ..and the Marina cut it out with a chain saw..Paid $100.00 for it..
Re: Chrysler Marine V-8s [Re: maundmotorworks] #302535
04/28/09 10:46 PM
04/28/09 10:46 PM
Believe it or not, that's not the first engine I've removed with a chainsaw. ...
Long time ago I was helping junk out an ugly old barge only thing worthwhile was the Chrysler flathead marine. I was roaring along cutting up the boat into sections with my saw, and throwing the junk on a trailer.
Went screeching along the bilge, a little water in the bottom and kerfreekin bloowie!!!! We, me it, the saw, the whole darn world stopped rotating. I can still see the stars in my eyes sometimes. I'd hit a nice big brass drain [Edited by Moparts - Keep it clean], right in the bottom of the bilge. Big 'ol McCullock never did run quite "straight" after that!!!
Re: Chrysler Marine V-8s #302536
04/28/09 11:10 PM
04/28/09 11:10 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I have a 383/260HP too, I could have got the velvetdrive too but I didn't.
Mitch
Re: Chrysler Marine V-8s [Re: 500ciDuster] #302537
04/29/09 06:01 AM
04/29/09 06:01 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
I worked on inboard motors like that 383 for 10 years at a wood boat shop here in town. Only thing is that if it was used in salt water and didnt get flushed out it could be very rusty in the cooling jackets. Of course if it was a closed cooling system or used in fresh water then your fine.
I still have a 69 440 from a house boat with all its boat stuff still attached, someday I'll find something to put it in
Coolest motor I got out of a boat was a 409 dual 4 barrel motor that turned out to be from a 62 Impala! IT was 100% complete and running for $1000.00 I sold off the boat crap and had it ready to put in my 65 biscayne wagon when someone found out I had it and made me an offer I couldnt refuse!!!!!!!!!
Re: Chrysler Marine V-8s [Re: High Impact] #302538
04/29/09 07:08 AM
04/29/09 07:08 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I had a 392 Hemi from a boat years ago. It was the counter motor. It had 3 little 2bbl carbs on it. I hung on to it for years and one day I opened my outside storage shed and it was gone, every piece of it too. I had disassembled it when I got it to see what all was differant from the regular motor. Nobody in my family ever owned up to taking it.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Chrysler Marine V-8s [Re: High Impact] #302539
04/29/09 07:10 AM
04/29/09 07:10 AM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
I am almost sure a friend of mine has a pair of old marine hemis (354s?). Is there a market for these? He is near tampa FL.
Re: Chrysler Marine V-8s [Re: hemibeep] #302540
04/29/09 08:44 AM
04/29/09 08:44 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
How about a marine 440-6 pak air cleaner, same as shown in the 1971 brochure...
Re: Chrysler Marine V-8s [Re: mccannix] #302541
04/29/09 08:46 AM
04/29/09 08:46 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
or...anyone need a smallblock marine bellhousing
Re: Chrysler Marine V-8s [Re: High Impact] #302542
04/29/09 10:24 AM
04/29/09 10:24 AM
minnesota
Kirby Offline
Kirby  Offline
minnesota
I know where 2 marine 440's are. Probably R&L matched pair. I have a 58 Century Resorter with a Cadillac Crusader, twin 4's, 300 hp. Haven't fired it yet- but should really fly!
