Guess the Dyno Results - 572 CID B1 original heads #3025006
03/17/22 09:10 PM
03/17/22 09:10 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I expect to have my engine on the dyno this weekend. Let's hear some educated guesses!
Engine Summary:
572 CID (4.500” bore x 4.500” stroke) 14.3 CR
B1 original Heads, CNC Ported 429/326 cfm at 0.800” lift, milled to 60cc chambers, 332cc intake ports, 125cc exhaust ports
T&D paired rocker arms 1.7 ratio, part number 8013, 5/8” shafts
B1 cast single 4-barrel intake manifold with RB spacers.
ICON Elite forged Pistons # IC433CAKTS gas ported with rings & 0.185” wall Trend wrist pins, 1.355 Compression height, -6.5cc net relief
Rings 0.043" top SS with CrN, 1/16" Napier 2nd, 3/16" oil ring
Cometic 5-layer MLS head gaskets 4.530” dia x 0.056” thick
Cam duration 282/295 at 0.050”, 0.800” lift, 113 LSA
7/16 dia Comp Cams pushrods, 0.165” wall, ball-ball ends, pushrod oiling
Headers have 8" of 2-1/8" primary tubes, then 21" of 2-1/4” tubes with 4” collectors
The initial pulls will be with an 1150 Dominator and 116 octane Sunoco Maximal race gas.
Then I will switch to the bracket racing carb I will be running in the car. APD 4150 series "1000 cfm" and pure alky (methanol).
If anybody has a similar dyno result, please post it. I am not really sure what this thing will make.
https://board.moparts.org/ubbthread...3230/572-b1-org-part-1-buying-parts.html
https://board.moparts.org/ubbthread...1-org-part-2-component-observations.html
https://board.moparts.org/ubbthread...2-b1-org-part-3-machine-shop-report.html
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2928218/572-b1-org-part-4-mock-ups.html
https://board.moparts.org/ubbthread...66856/572-b1-org-part-5-build-notes.html
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025010
03/17/22 09:22 PM
03/17/22 09:22 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
875 gas
920 alcohol
....BAD A$$ STREET CAR.....
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025011
03/17/22 09:26 PM
03/17/22 09:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
1025 Gas
1060 Alky.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: NITROUSN] #3025014
03/17/22 09:30 PM
03/17/22 09:30 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
910HP on gas
Alan Jones
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: NITROUSN] #3025015
03/17/22 09:30 PM
03/17/22 09:30 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
980 (gas)
1025 (alky)
"Any fool can know. The point is to understand"
- A. Einstein
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: EvilB1Dart] #3025024
03/17/22 10:32 PM
03/17/22 10:32 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Interesting estimates so far.
IMO, I think the "little" 4150 carb will limit the airflow of the 572 CID at higher rpm (7000 ish), and therefore make less peak horsepower. Even if it makes more peak torque around 5500-5700 rpm.
I really want to know what rpm the peak torque and peak horsepower will occur.
Nothing fancy on this engine. The only "exotic" part is the Predator offset distributor. I got a good deal on one that had only 1 season of use. So the typical MSD billet distributor will stay with my old 570 hp iron head engine.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025036
03/17/22 11:44 PM
03/17/22 11:44 PM
AndyF Offline
AndyF  Offline
I'd expect around 900 hp on race gas with that carb. Probably see peak power around 7000 rpm with the 1150 carb. Has the intake been ported or is it as cast? I know those are pretty good intakes as cast but porting will still help a bit. Not so sure on the torque, maybe 750 at 5500 rpm?
We've run a bunch of engines that size, with good heads, big cams, same compression, same size carbs on the dyno this year but nothing with that exact combo of parts. Everything similar we've run has been right around 900 hp at 7000 rpm.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025037
03/17/22 11:46 PM
03/17/22 11:46 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Peak torque 5800, HP 6900. My bet is on gas with the bigger carb 960 HP.
Doug
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: AndyF] #3025053
03/18/22 04:43 AM
03/18/22 04:43 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I bought the intake used, so I don't know the history. Visually, I can see some clean up inside. But I don't know how much.
The intake manifold exit openings are slightly larger than the Koffel gaskets. I "ported" the 3/4" thick RB spacers to transition to the even larger heads. Then I used a Flat Out Gasket that had the right size openings .
More info on Part 5 build notes.
Link to Part 5 - intake
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025064
03/18/22 07:50 AM
03/18/22 07:50 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
For comparison, we have a .030 over 572 (580) with less lift (.768 gross), less flow (around 395), less C/R (12.4) but more carb (2 x 1150 TR). According to Wallace, it makes around 910hp on a good day (142 mph + @ 4023lb). Best shift point seems to be around 6800, rpms fall back 500rpm or so.
So I'm guessing around 940 on gas and 1000 on Alcohol popcorn
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: Tig] #3025065
03/18/22 08:06 AM
03/18/22 08:06 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I'm not qualified to make an educated guess, but am looking forward to the results. coffee
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: Brad_Haak] #3025085
03/18/22 09:16 AM
03/18/22 09:16 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
On gas it should go 1075+Hp no problem.
69 GTX 68 Road Runner
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: JERICOGTX] #3025096
03/18/22 09:49 AM
03/18/22 09:49 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’d be looking for around 925-950 with the 1150 and race gas.
No vacuum pump?
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: fast68plymouth] #3025100
03/18/22 10:16 AM
03/18/22 10:16 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Originally Posted by fast68plymouth
No vacuum pump?
That's right; no vacuum pump. Nothing fancy.
It will be interesting to see the difference in the Dominator on gas and the 4150 series alky carb.
I had a hard time finding a dyno that would do this motor. Some "reasons" various shops gave me:
1) We only dyno engines we built
2) We don't have the stuff to do a Big Block Mopar (one had 6-bolt but not 8-bolt crank connector)
3) We dont' run alcohol in our dyno flow meters.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025102
03/18/22 10:18 AM
03/18/22 10:18 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If not vacuum pump, hopefully you're going to have some positive evac via the collectors? So, with evac I'm guessing assuming heads and intake are 'good'? I'd assume 960-980 with the 4500 on gas. It'd be nice if you moved the cam 2 degrees to see and report on the results. Also from what i remember the belt in those distributors would retard the advance a couple of degrees at higher speed. Either way NO judgement and GOOD LUCK!!!
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: HardcoreB] #3025108
03/18/22 10:32 AM
03/18/22 10:32 AM
So. Burlington, Vt.
So. Burlington, Vt.
I have seen enough “strange looking” dyno sheets over the years to know they definitely don’t all spit out the same numbers.
The combo is pretty straight foward, and unless something is “wrong” with the motor, it’s going to make good power.
I feel that whatever the numbers are........ they could easily vary by over 50hp if the engine were tested on some different dyno services.
Just work on the tune up, get the best numbers you can....... and don’t get too excited about whatever the actual number is.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025124
03/18/22 11:15 AM
03/18/22 11:15 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I am not educated but will say like 1000-something just to play along. Good luck with it!
Rich H.
Esse Quam Videri
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025139
03/18/22 11:46 AM
03/18/22 11:46 AM
AndyF Offline
AndyF  Offline
No vacuum pump?
Those are pretty common answers. The place I work with usually won't dyno engines they didn't build since it often turns into a pig pile. He has modified his policy over the years so he'll dyno engines from certain shops that he trusts but it still goes sideways on a regular basis. Not having the correct motor mounts or crank adapters or headers is also a common problem. It can cost upwards of a $1000 to equip the dyno for each engine model and if the customer doesn't want to pay for it then why should the dyno operator. A BB Mopar is fairly common so you should be able to find a shop with the setup you need but good luck if you want your nailhead run on the dyno or a 409 or something like that.
Alcohol shouldn't be an issue but I'd charge extra since it takes time to flush the system out afterwards. You're probably looking at $2000 for a couple of days of testing including switching carbs and fuel and doing multiple pulls to dial in the timing and jetting.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: AndyF] #3025144
03/18/22 11:57 AM
03/18/22 11:57 AM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
Like yours,...... mine was #1050 HP before the Procharger.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: fast68plymouth] #3025146
03/18/22 12:05 PM
03/18/22 12:05 PM
The first B1 bracket motor I built and dyno (551 C.I.) made 920 HP with a 1400+ CFM Dam Best carb that was way to rich at WOT on C12 I think, the customer provided the fuel.
That was with the stock B1 cast Dominator intake and right at 13.0 to 1 compression with a World iron block.
I'm in the process of making a 572 C.I. B1 KB aluminum block bracket motor running E85 with a pair of Mark Sullens E85 Dominator carbs flowing around a 1000 CFM each, I'm hoping and shooting for 1000 + HP on pump E85 luck
I may add around 550 HP of NOS to it later for a local No Pep deal devil work
