Re: Guess the Dyno Results - 572 CID B1 original heads [Re: Cab_Burge] #3025663
03/20/22 09:35 AM
03/20/22 09:35 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
After supplying a BB Mopar bellhousing, 8-bolt manual transmission flywheel, starter, etc. the dyno shop that said they will test my engine called and said they can't do it.
Their dyno mounting has several hole patterns (trans patterns) to bolt the dyno to the engine bellhousing; but none fit the Chrysler A833 manual transmission.
A833
5.28" wide top holes
7.125" wide bottom holes
7.875" height from top to bottom holes
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025669
03/20/22 10:04 AM
03/20/22 10:04 AM
Washington
madscientist Offline
Washington
A833
I will go out to the shop today and look at mine. I’ll see if mine will take that pattern. I haven’t gotten my dyno up and running yet but it’s close. Waiting on some hardware and a couple of water pumps.
Now that I think about it...it may not have the 833 pattern on it. I have a scatter shield and it has the 833 and GM pattern on it. I just can’t believe there isn’t an 833 pattern on it though.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025680
03/20/22 10:47 AM
03/20/22 10:47 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You most likely need a bell from a big block truck. As I remember they will bolt up to several transmissions NP-435, NP-445 and possibly more. Someone on Moparts may have one you could borrow. Here is a link to one that could work . Bell
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025689
03/20/22 11:21 AM
03/20/22 11:21 AM
AndyF Offline
AndyF  Offline
Well that is a bummer. I haven't run into that exact problem before but I'm familiar with those types of issues. There are some options but they'll all cost money. Here is one option: https://www.holley.com/products/drivetrain/bellhousings/engine_dyno_stand/parts/77-251
Here is another option: https://www.holley.com/products/drivetrain/bellhousings/engine_dyno_stand/parts/RM-8001
I'd think that the dyno shop would be interested in having one of these universal bellhousing on hand since then they can make more money in the future by testing BB Mopar engines. Maybe split the cost with them or something.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025732
03/20/22 01:47 PM
03/20/22 01:47 PM
AndyF Offline
AndyF  Offline
Here is another option, BB Mopar to Muncie bellhousing. You would want to verify the pattern that they have on the dyno but I would assume that Muncie would be one of the choices.
https://www.holley.com/products/drivetrain/bellhousings/mopar/parts/RM-6078
You can also redrill your existing bellhousing and/or weld a plate on it with the correct pattern. All depends on which way works out the easiest for you.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: AndyF] #3025733
03/20/22 01:48 PM
03/20/22 01:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
For the typical SF situation, you also need a centering ring to locate the bell housing to the absorber.
The Mopar bell housing also puts the engine farther forward, and has the crank farther away from the input shaft.
In order to get the pilot of the shaft centered on the crank, you either need a longer than “standard” shaft, a spacer behind the shaft to move it closer to the crank, or an extension located at the back of the crank....... the latter of which is what we do here.
The bellhousing gets drilled to facilitate two of the lower absorber mounting holes, and we use bolts with nuts to secure it.
We bought the correct centering ring from SF to locate the bellhousing.
None of it is hard........ but someone has to “want” to make it happen.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: fast68plymouth] #3025756
03/20/22 02:31 PM
03/20/22 02:31 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Would a JW Ultra bell for a BB to glide and a wheel and adapter work????? Todd
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: sasquatch] #3025843
03/20/22 08:12 PM
03/20/22 08:12 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I thought about that. Then I looked at the JW bell on my PowerGlide. It uses the PG pump holes to mount to the transmission. So that pattern is certainly not on his old absorber attachment plate (not a transmission to bellhousing pattern). He will be returning my engine and parts Monday. His full time job is only 10 minutes from my house. The dyno is at his house.
He agreed it can be done, but it will take modifying/making parts and he is not going to do that. He actually does mostly NASCAR cup engines. He has a "plate with torsion springs" for the small dia Cup clutch, as well as the "street clutch" plate that does fit on the flywheel I gave him.
For other Moparts members, Both the bellhousing and flywheel were borrowed, so I can't let him modify them. He would need to buy his own to modify. He said he is not in a position to do that.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025844
03/20/22 08:19 PM
03/20/22 08:19 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I know I am a long ways away, but if you could find someone that has a DTS/SF powermark there is no bellhousing needed.
Joe
Without Data, you’re just another guy with an opinion.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025916
03/21/22 02:09 AM
03/21/22 02:09 AM
Washington
Washington
A833
Yep, my dyno won’t take an 833 pattern either. I never noticed because any time I’ve taken my junk to the dyno I always took my scatter shield with me and we used that. It has the GM pattern on it.
So I never even looked at my dyno. So now tomorrow I will be ordering a universal fit bell housing so I don’t have to screw around.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: LA360] #3025928
03/21/22 06:57 AM
03/21/22 06:57 AM
NW Indiana
fbs63 Online content
fbs63  Online Content
NW Indiana
Originally Posted by LA360
910HP on gas
This.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: fast68plymouth] #3025950
03/21/22 08:48 AM
03/21/22 08:48 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by fast68plymouth
I have seen enough “strange looking” dyno sheets over the years to know they definitely don’t all spit out the same numbers.
The combo is pretty straight foward, and unless something is “wrong” with the motor, it’s going to make good power.
I feel that whatever the numbers are........ they could easily vary by over 50hp if the engine were tested on some different dyno services.
Just work on the tune up, get the best numbers you can....... and don’t get too excited about whatever the actual number is.
Well said! Jim, sorry for your current difficulties!
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: HardcoreB] #3025967
03/21/22 09:54 AM
03/21/22 09:54 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Jim - Sorry to hear that things didn't go as planned. Maybe I missed it, but do you have a Plan B?
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: Brad_Haak] #3025971
03/21/22 10:26 AM
03/21/22 10:26 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
This was already plan "Z". Called lots of places the past couple months...
With all the old Mopar racers and general car racing in North Carolina, I am amazed nobody is dyno testing Hemi engines anymore. Only if they built the engine.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025986
03/21/22 10:51 AM
03/21/22 10:51 AM
So. Burlington, Vt.
So. Burlington, Vt.
I guess it’ll depend in part on how far you’re willing to drive.
Alan P has a Mopar friendly dyno in NJ, and there’s always Barton in Pa.
You could also call Todd Marsh and see about the shop he uses.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3025995
03/21/22 11:09 AM
03/21/22 11:09 AM
an8sec70cuda Offline
Jim, there's an engine builder/machinist in Conway, SC, named Jesse Causey that has a dyno and I believe he has the ability to dyno a Mopar BB. Jesse is very good at what he does, but works a limited schedule nowadays. twocents
I have never dealt w/ him myself, but member here "ek3" has.
Might be worth a shot to check w/ him if Todd Marsh can't hook you up. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: an8sec70cuda] #3025999
03/21/22 11:17 AM
03/21/22 11:17 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Is coming back to MD too far? Burtonsville Performance Machine was OK w/ dyno-ing my engine before I decided to make the trip back to VT and have Dwayne handle it. And BPM does enough Stock Eliminator stuff I'd be shocked if they can't handle a G2 Hemi / 8-bolt crank deal.
Edit: If BPM can do the job, it's 40 miles from me (1 hour + drive depending upon traffic) and you're welcome to crash here night before / night after to save on travel expenses. Anyway, just throwing that out there.
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3026002
03/21/22 11:27 AM
03/21/22 11:27 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A833
Jim if we lived closer I could lend you the Lakewood blowshield we used for the Enginemasters , I drilled the needed hole pattern in it so that wouldn't have been an issue.
On that note if it would work I can ship it to you and pick it up on my way back from FL. late May , early June ?
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: 440Jim] #3026018
03/21/22 12:28 PM
03/21/22 12:28 PM
gregsdart Offline
gregsdart  Offline
Jim, thankyou for sharing a great build,as well as help on my project. I am sort of lost on what power it will make, but i will hazard a guess of 980 hp at 7200 rpm, and 770 tq at 5600 rpm. What ever it comes out at, it will be a stout ride👍
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Guess the Dyno Results - 572 CID B1 original heads [Re: gregsdart] #3026026
03/21/22 12:53 PM
03/21/22 12:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As said find a DTS/Superflowand there is no bell needed. For one requiring a bell use a BBM to PG adapter plate like sold by ATI and TCI and you should be golden. We have one here we use just for dyno stuff if we use a local shop that uses a bell set up. Not an insurmountable problem for sure. Finding someone with a smidgen of knowledge about BBM and dynos can be the hard part.
AS for power I can tell you my 4150 carb is about 20 HP down on my 540" B1. IMO a vacuum pump is not a "fancy"part these days and I belive is something any race engine needs and will benefit from. As for power compression ratio will kill some, I have made lots of power on unported intakes and seen very very little from ported ones, especially at 572". Id say you will be in the 915ish area if you can get it done.
