Another 4 link question- Diagonal track bar #3024737
03/17/22 12:01 AM
03/17/22 12:01 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
Question is: when you adjust the 4 link bars either up/down in front or rear bracket, does that require you to readjust the diagonal track bar to keep the rear exactly in position side to side? In studying the geometry of my 4 link, moving the arms up or down should slightly change the exact position of the diag bar/rear axle location pulling or pushing the rear sideways. Is it so slight that nobody readjusts for it, or am I wrong?
Thx
Re: Another 4 link question- Panhard bar [Re: Chargerfan68] #3024740
03/17/22 12:11 AM
03/17/22 12:11 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That’s why I used a wishbone, but if P bar is on bottom bars I don’t see it changing, still on the same plain. Now if you adjust lower heims in or out then I think it would change
Re: Another 4 link question- Panhard bar [Re: cudaman1969] #3024777
03/17/22 08:14 AM
03/17/22 08:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Do you have a pan hard bar? Or a diagonal track bar? With a diagonal bar the adjustment will change after a I/C or preload adjustment.
Doug
Re: Another 4 link question- Panhard bar [Re: dvw] #3024782
03/17/22 08:43 AM
03/17/22 08:43 AM
New York, USA
New York, USA
Yes…a diagonal track bar. So, after each IC or preload adjustment, you have to readjust the track bat for axle lateral position? Seems like alot of additional work for each adjustmant. Really didn’t want housing location to change with each 4 link adjustment. Do you all actually readjust diagonal bar after adjusting 4 links, or you just let it be.?
Thank you
Re: Another 4 link question- Panhard bar [Re: Chargerfan68] #3024811
03/17/22 10:39 AM
03/17/22 10:39 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I have adjusted right lower bar several times never touched diagonal parnard
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Another 4 link question- Panhard bar [Re: 440lebaron] #3024850
03/17/22 12:32 PM
03/17/22 12:32 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Lets be clear
- A Panhard bar runs from the frame to the rear axle assembly parallel to the axel assembly - requires no adjustment with four link adjustment
- A Diagonal link runs diagonally from front to rear Diagonally from one side to the other and horizontally parallel to the lower suspension members - depending on how its installed should not require adjustment unless you are changing lower bar length (wheel base length change)
- A Wish bone is a three point lateral control that can be either mounted above or below the axle and with the single point forward or reward. A slip joint on the single point allows for the arc of suspension travel and any pinion angle change - does not require adjustment with four link adjustments.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Another 4 link question- Panhard bar [Re: W.I.N. Racing] #3024870
03/17/22 01:32 PM
03/17/22 01:32 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
If you don't touch the bottom bars, the diagonal doesn't need to be fooled with. You can twist the top bars anyway you want. The housing will remain centered and square.
Easy way is measure the driveshaft side to side at ride height to the rear driveshaft loop or 4 link brackets. Make your moves, confirm or correct side to side back to those dimensions. Eliminates having to drop string lines, etc.
Making a change on the bottom bars location? Don't loosen the jams. If the housing was square before, it won't change unless your brackets were installed by a blind man.
Re: Another 4 link question- Panhard bar [Re: Chargerfan68] #3024872
03/17/22 01:41 PM
03/17/22 01:41 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I readjust it not that hard to get the axle housing back to center.
best so far 8.53 @ 158.59 MPH 60'1.240
