Who sell's them ? #3022905
03/11/22 01:34 PM
03/11/22 01:34 PM
saint paul mn.
johnzgarage Offline OP
saint paul mn.
Im looking for the factory style fuel bowl inlet fittings for the superstock hemi 770 carbs. Looks like the newer resto carbs have a larger inlet fitting size that are to big. The orig carbs have a smaller inlet size. Anyone have a part number or a idea what will work ???
[img]fitting_LI (4)[/img]
Re: Who sell's them ? [Re: johnzgarage] #3022915
03/11/22 01:45 PM
03/11/22 01:45 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
If nobody here is able to help, you may want to check with Woodruff Carburetor Specialists in Ohio. The owner races an older A-body Super Pro car, IIRC, and does rebuild and nice restoration work. I forgot his name... (Dave, maybe?), but the phone number is (330)799-9479.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
