If nobody here is able to help, you may want to check with Woodruff Carburetor Specialists in Ohio. The owner races an older A-body Super Pro car, IIRC, and does rebuild and nice restoration work. I forgot his name... (Dave, maybe?), but the phone number is (330)799-9479.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
