alternator case cleaning #3021188
03/06/22 06:41 AM
03/06/22 06:41 AM
sw chicago
RAH Offline OP
RAH  Offline OP
sw chicago
Is there a way to clean old alternator (1968) case back to looking like original looked?
Re: alternator case cleaning [Re: RAH] #3021195
03/06/22 08:55 AM
03/06/22 08:55 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I used a blast cabinet that had wore out glass media and it turned out perfect no material removed. Not sure you can run into that situation but that's how I did mine.
1969 Hemi Roadrunner 2nd owner
Re: alternator case cleaning [Re: 69hemibeep] #3021196
03/06/22 09:22 AM
03/06/22 09:22 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Using baking soda instead of glass beads or sand is real gentle.
Re: alternator case cleaning [Re: 69hemibeep] #3021197
03/06/22 09:26 AM
03/06/22 09:26 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Years ago there was some discussion about "oxalic acid" for cleaning up parts. I bought some and did a test with some scrap cast aluminum coil spring spacers. The acid is marketed as "wood bleach" and I found it at a local hardware store. I heated water up to boiling, poured it into a plastic container in the garage and added the wood bleach crystals. I soaked one of the spacers in the solution and it removed all of the white rust. I scrubbed it a few times with a tooth brush and it did a good job of cleaning the aluminum. I took a comparison picture to show how it worked but I'm not finding it at the moment.
Re: alternator case cleaning [Re: burdar] #3021210
03/06/22 10:29 AM
03/06/22 10:29 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Fine sand and say no to high pressure.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: alternator case cleaning [Re: 340SIX] #3021236
03/06/22 12:00 PM
03/06/22 12:00 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Blast cabinet using crushed walnut shells.
Re: alternator case cleaning [Re: 469runner] #3021251
03/06/22 12:53 PM
03/06/22 12:53 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Balotini ah 175-325 glass beads that are worn out, baking soda, walnut shells that are worn out, fresh sharp shells dig in a little. The real question is how do you duplicate that gold flash finish it had, you know that look you know when you see it but can't explain it. Here is a NOS 67 alternator back, you can see it was plated, or dipped then machined.
Re: alternator case cleaning [Re: 4406bbl] #3021288
03/06/22 03:11 PM
03/06/22 03:11 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Bonderite/Alodine1201, ( same thing), Google it to find a supplier and directions. I've found dipping for 2 to 3 mins. will get you what you want.
Re: alternator case cleaning [Re: carteravs] #3021302
03/06/22 04:23 PM
03/06/22 04:23 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Thanks, looks like I have some and never thought to try that.
Re: alternator case cleaning [Re: 4406bbl] #3021333
03/06/22 06:40 PM
03/06/22 06:40 PM
Ohio
carteravs Offline
carteravs  Offline
Ohio
Ithink the 1001 is a clear coating.
Re: alternator case cleaning [Re: carteravs] #3021769
03/08/22 05:37 AM
03/08/22 05:37 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Alodine comes in clear or yellow. You need the yellow.
