Re: alternator case cleaning
[Re: RAH]
#3021195
03/06/22 08:55 AM
03/06/22 08:55 AM
Posts: 1,385 Az
69hemibeep
Az
I used a blast cabinet that had wore out glass media and it turned out perfect no material removed. Not sure you can run into that situation but that's how I did mine.
1969 Hemi Roadrunner 2nd owner
[Re: 469runner]
#3021251
03/06/22 12:53 PM
03/06/22 12:53 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
Balotini ah 175-325 glass beads that are worn out, baking soda, walnut shells that are worn out, fresh sharp shells dig in a little. The real question is how do you duplicate that gold flash finish it had, you know that look you know when you see it but can't explain it. Here is a NOS 67 alternator back, you can see it was plated, or dipped then machined.
[Re: carteravs]
#3021302
03/06/22 04:23 PM
03/06/22 04:23 PM
4406bbl
Nebraska
Bonderite/Alodine1201, ( same thing), Google it to find a supplier and directions. I've found dipping for 2 to 3 mins. will get you what you want. Thanks, looks like I have some and never thought to try that.
[Re: carteravs]
#3021769
03/08/22 05:37 AM
03/08/22 05:37 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Alodine comes in clear or yellow. You need the yellow.
