Four-speed guys #3020907
03/04/22 08:54 PM
03/04/22 08:54 PM
CA.
RAY1969CARS Offline OP
CA.
Hi I have a hurst competition shifter and I wanted to add a reverse lockout wanted to know if that was shifter specific or can you buy the lever and install it on any Shifter body? And if so does anyone know where I can get one? Thank you Mopar or no car
Re: Four-speed guys [Re: RAY1969CARS] #3020914
03/04/22 09:31 PM
03/04/22 09:31 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I got one from Jamie Passon years ago.
Re: Four-speed guys [Re: Jeremiah] #3020931
03/04/22 10:06 PM
03/04/22 10:06 PM
CA.
CA.
Is this my only option for a competition plus shifter
434B99BE-3BB1-48CC-88B1-A25DA0F4525A.jpeg3C53EAA6-97B7-4163-AA4C-A5FEC8062E5F.pngA020ADE3-B53A-499B-9070-1442E2AE64F9.png
Re: Four-speed guys [Re: RAY1969CARS] #3020980
03/05/22 03:40 AM
03/05/22 03:40 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The comp plus in my gts has a "T" handle similar to the first post. Did you call brewers or passon? I think the reverse lockout kit might be reproduced.
Re: Four-speed guys [Re: Jeremiah] #3020985
03/05/22 07:44 AM
03/05/22 07:44 AM
Washington
madscientist Offline
Washington
If neither of those two don’t have the reverse lockout kit, I’m pretty sure shiftdoctor.com has them. And it may be shiftdoc.com but it’s easy to search and find the correct address.
Re: Four-speed guys [Re: Jeremiah] #3021036
03/05/22 01:21 PM
03/05/22 01:21 PM
CA.
CA.
Calhow much power can a 833 handle ? Before it breaks using slicks or drag radials
Re: Four-speed guys [Re: RAY1969CARS] #3021051
03/05/22 02:54 PM
03/05/22 02:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I found out years ago that you have to feed the drivetrain in 4 speed drag races, you can feed it tires, axles, U joints, clutch parts or whatever else it needs to continue to be raced whiney shruggy
Re: Four-speed guys [Re: RAY1969CARS] #3021054
03/05/22 03:07 PM
03/05/22 03:07 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
There are many factors at play. A clutch that slips at the hit and controlling the suspension are both important components of not killing parts. Weight, hp, gear, how the car leaves and how it behaves going down the track all com in to play.
An a833 with aluminum housing/tailshaft/side cover and faceplated 9310 gears from Liberty will run 4500ish with all of a billet shifter mount and bearing retainer. Add redline MTL fluid, ARP hardware and a shifter its around 5k. This is best case scenario for a light weight, strong a833. Anything less than the above (case material is arbitrary) will cause reliability to suffer.
As for how much power something will handle or make I am done with those discussions on this website it is pointless to debate something when the only data that anyone here sees as valid is the data that supports their opinion. Now if you want to talk about expected results in my opinion I would think that you would start having problems around 700 horse and 3500 lb if you could keep the clutch from breaking everything behind it. Part of the reason I have not had any parts breakage so far is because I ramp in the power via a nitrous hit on a Progressive controller and a clutch tamer on the pedal. Otherwise the stock eight and three quarter would have been grenaded a while back. I am still paranoid enough that a Dana 60 is going in its place
