B1 header flanges ??? #3020529
03/03/22 03:36 PM
03/03/22 03:36 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Ok...who makes a good one?? and i mean like Smith Innovations. He just called me and he is not making them anymore. Im looking for something sturdy 3/8 something thats 2 1/4 and something thats not hard to get a tube into. I dread putting a round peg in that square hole ... shruggy Oh yea an stainless steel too.
....BAD A$$ STREET CAR.....
Re: B1 header flanges ??? [Re: n20mstr] #3020540
03/03/22 04:00 PM
03/03/22 04:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
SPD Exhaust..
Re: B1 header flanges ??? [Re: Al_Alguire] #3020545
03/03/22 04:13 PM
03/03/22 04:13 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted by Al_Alguire
SPD Exhaust..
yep
http://www.spdexhaust.com/Header-FlangesB.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B1 header flanges ??? [Re: n20mstr] #3020550
03/03/22 04:17 PM
03/03/22 04:17 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Stainless Headers has some good you tube video's showing how to put a round peg into a square hole.
69 GTX 68 Road Runner
Re: B1 header flanges ??? [Re: pittsburghracer] #3020552
03/03/22 04:20 PM
03/03/22 04:20 PM
PA.
"Little"John
"Little"John
PA.
they used to be real pretty but I cut them apart to make things easier
[Linked Image]Untitled by John Cadamore, on Flickr
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 header flanges ??? [Re: n20mstr] #3020832
03/04/22 03:45 PM
03/04/22 03:45 PM
NC
440Jim Offline
440Jim  Offline
NC
... 2 1/4 and something thats not hard to get a tube into. I dread putting a round peg in that square hole ... shruggy Oh yea an stainless steel too.
You will have to do some amount of "squaring" or flatening the round tube to put it in the header flange. You run out of room on the head, so the flange needs to be less than 2.375" tall and a round 2.25" tube opening won't leave much for sealing above/below the port.
Attached picture from SPD
Re: B1 header flanges ??? [Re: 440Jim] #3020939
03/04/22 11:05 PM
03/04/22 11:05 PM
NC
440Jim Offline
440Jim  Offline
NC
FWIW,
My heads were ported by the previous owner/shop. It may have different dimension than yours.
I had a local laser cutting shop make a couple pairs of flanges (mild steel). And I made a simple jig to "form" the tube to the flange shape. It still takes some hammer tapping and peening before welding.
But I am happy with the result. My headers are finally finished welded....
Re: B1 header flanges ??? [Re: 440Jim] #3020941
03/04/22 11:13 PM
03/04/22 11:13 PM
NC
440Jim Offline
440Jim  Offline
NC
Your could "borrow" the forming tool (used in a flat faced vice).
But it is made for the flanges I have.
Re: B1 header flanges ??? [Re: 440Jim] #3021023
03/05/22 12:07 PM
03/05/22 12:07 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I love the tool! I need to make one up
Re: B1 header flanges ??? [Re: Forest] #3021029
03/05/22 12:41 PM
03/05/22 12:41 PM
NC
440Jim Offline
440Jim  Offline
NC
I suggest making the height of the forming tool roughly 0.035" less than the height of the flange opening. The vice pushes the tube flat, but it can spring back somewhat.
The center body (green) helps to prevent the flat part of the tube from "buckling" or bending toward the center as the tube is formed.
