Should this sit flat? Motor mount #3019855
02/28/22 11:08 PM
02/28/22 11:08 PM
BDW Offline OP
BDW  Offline OP
I’m fitting this stock biscuit motor mount to a Holley 3G bracket.
The pressed fit splines and the oversized dimple aren’t allowing the mount to sit flat on the bracket?
Is this an issue, how does it compare to a stock set-up?
Thx
Re: Should this sit flat? Motor mount [Re: BDW] #3019858
02/28/22 11:14 PM
02/28/22 11:14 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would work it until it fits correctly. It will loosen up if you assemble it like that twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Should this sit flat? Motor mount [Re: BDW] #3019862
02/28/22 11:40 PM
02/28/22 11:40 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Either ground away the mount, or BETTER YET tell Holley they need to improve their bracket
Re: Should this sit flat? Motor mount [Re: PhillyRag] #3019865
03/01/22 12:09 AM
03/01/22 12:09 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Yep. I would enlarge the holes the stud and the dimple fit into so they actually fit correctly.
Re: Should this sit flat? Motor mount [Re: BDW] #3019878
03/01/22 01:14 AM
03/01/22 01:14 AM
Boise
Moparteacher Offline
Boise
Taper the holes in the bracket. No need to enlarge the full depth of the holes.
Re: Should this sit flat? Motor mount [Re: Moparteacher] #3019904
03/01/22 10:02 AM
03/01/22 10:02 AM
VA
dragon slayer Offline
VA
Is the bracket the problem or that rubber mount?
Re: Should this sit flat? Motor mount [Re: dragon slayer] #3019908
03/01/22 10:08 AM
03/01/22 10:08 AM
BDW Offline OP
BDW  Offline OP
The holes in the bracket are just large enough for the 1/2” stud.
The dimple and the splines on the mount stud are larger than 1/2”
So how large are the holes in a factory bracket?
Trying to determine whether I should drill the bracket or grind the mount.
Thx
Re: Should this sit flat? Motor mount [Re: BDW] #3019927
03/01/22 11:18 AM
03/01/22 11:18 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Nearly all new mounts are garbage, in both fit and material. We tried to fit new mounts on stock motor brackets and stock k-member for a 440 in a '70 Charger. Nothing would fit properly. Went back to some older used mounts and everything fit.
Re: Should this sit flat? Motor mount [Re: BDW] #3019976
03/01/22 01:37 PM
03/01/22 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Countersink the holes in the bracket enough for the mount to sit flush.
Re: Should this sit flat? Motor mount [Re: John_Kunkel] #3020767
03/04/22 12:25 PM
03/04/22 12:25 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I'm sure the dies they use are at least ten times over their original cycle rate, so the dimple is a large mound instead of a small, crisp dimple.
