70 383 330hp vs 335hp #3018099
02/23/22 03:46 PM
02/23/22 03:46 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Hi,
What is the difference in the 1970 383 4bbl 330hp non- R/T vs the 383 4bbl 335hp R/T engines? Or is there no difference?
I believe they are both "N" codes? Both HP blocks? In E-bodies.
Thanks!
1970 Dodge Challenger T/A
Re: 70 383 330hp vs 335hp [Re: jeff968] #3018107
02/23/22 04:01 PM
02/23/22 04:01 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
From previous discussions I think it's just the camshaft? But 5HP seems too little for the difference in cam specs?
There's a similar situation among C bodies with 440's, there's the standard 350HP, the 360HP police package and the 375HP version. The 360HP would be similar to the the 383 330HP? So the small cam costs the 383 5HP vs the 440 at 15 HP? shruggy
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 70 383 330hp vs 335hp [Re: 3hundred] #3018111
02/23/22 04:20 PM
02/23/22 04:20 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Carbs are different too, Carter on 330 hp and Holley on 335 hp I'm pretty sure.
And the 335 hp engines are painted hemi orange instead of blue, I'm sure that adds a hp or two. wink
Re: 70 383 330hp vs 335hp [Re: Mastershake340] #3018112
02/23/22 04:24 PM
02/23/22 04:24 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Thanks, but are they both "N" codes? JS23N0B and JH23N0B?
I know "L" is the 2bbl. I don't think there was an "M".
Re: 70 383 330hp vs 335hp [Re: jeff968] #3018116
02/23/22 04:29 PM
02/23/22 04:29 PM
Crook County, ILL
Crook County, ILL
My convertible is a JH27N0B. It's an automatic with a blue engine. Interestingly, a JH23 or JH27 N0B car with manual got an orange painted engine, Does that mean they got the 335 hp engine?
Re: 70 383 330hp vs 335hp [Re: Mastershake340] #3018147
02/23/22 05:41 PM
02/23/22 05:41 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I think you're seeing a year model difference there? In '68 and '69 pretty danged sure either version had the AVS. I_think_they switched to Holley in 1970 for the 383's? Referencing the 440's again, the lo po's got the Holley, hi po's the AVS, not sure about the police package but suspect strongly it was the AVS?
'69 300 Convertible
'16 300 S Hemi
Re: 70 383 330hp vs 335hp [Re: Mastershake340] #3018149
02/23/22 05:42 PM
02/23/22 05:42 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Pretty sure both N coded engines. Non a/c cars were 335hp with holley and orange paint, a/c equipped cars were 330hp with Carter AVS and blue paint
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 383 330hp vs 335hp [Re: 70gtx440dana] #3018157
02/23/22 06:00 PM
02/23/22 06:00 PM
Crook County, ILL
Crook County, ILL
I stole this chart of 1970 383 engines from another forum. Way too many variations to keep up with for a single engine option. shock
383 manual - E & B-body - with ECS (N95)
orange HP engine 335hp
---------- Holley R4217-A ---------- part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS
orange HP engine 335hp engine on b'cast 084 with A/C & 087 w/o A/C
---------- Holley R4367-A ---------- part number 3418 536 on b'cast 36
383 manual - E & B-body - w/o ECS & with "fresh air" (N96).
---------- Holley R4736-1A ---------- part number 3512 964 on b'cast 64
383 manual - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4738-1A ---------- part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS
blue engine 330hp
---------- Carter 4736S ---------- part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS
blue engine 330hp
---------- Carter 4732S ---------- part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)
blue engine 330hp
---------- Carter 4734S ---------- part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS
orange HP engine 335hp engine on b'cast 088
---------- Holley R4368-A ---------- part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96).
---------- Holley R4737-1A ---------- part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)
---------- Holley R4218-A ---------- part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS
orange HP engine 335hp engine on b'cast 089
---------- Holley R4369-A ---------- part number 3418 562 on b'cast 62
383 automatic - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4739-1A ---------- part number 3512 975 on b'cast 75
Re: 70 383 330hp vs 335hp [Re: Mastershake340] #3018174
02/23/22 06:57 PM
02/23/22 06:57 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I know, then I came along and muddied the waters with the '68 and '69's I regard as a basis since they were common when I started as a mechanic. I remember being surprised to see a Holley 4bbl on a 1970 383 e body back in the day. Another list...all the '69 4 bbl 383's were AVS, in 1970, almost all were Holley's. I think it was a cost issue, the Holley's were cheaper and had more problems. Why they kept the AVS on the hi po 440's? shruggy
https://www.thecarburetorshop.com/Kdodge.htm
'69 300 Convertible
'16 300 S Hemi
Re: 70 383 330hp vs 335hp [Re: 3hundred] #3018229
02/23/22 08:54 PM
02/23/22 08:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The # of variations is probably why the engine & trans codes were written on the valve covers.
Probably some sequence # as well on a tag, as they wouldn't be checking VIN stampings before installation.
As for the HP rating, those were more about marketing than real output.
Of all the 383s I've had, mostly in Road Runners, most of them ran fairly equally whether they had AC or not.
Some were stronger than others, and a couple were pretty "casual".
Mileage (17K - 130K) didn't seem to play a big part in their relative strength, oddly.
Re: 70 383 330hp vs 335hp [Re: topside] #3018296
02/23/22 11:43 PM
02/23/22 11:43 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Not sure if this was mentioned, but I remember A-body big blocks had a more restricted driver's side exhaust manifold.
E bodies too???
Joe
Re: 70 383 330hp vs 335hp [Re: jlatessa] #3018309
02/24/22 12:29 AM
02/24/22 12:29 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
different years, different engines & different body styles muddies the water
1970
"N-code" simply indicates 383 cu.in. 4BBL
E-body
383 4bbl 330hp - blue engine w/CARTER carburetor automatic ONLY (ONLY available in non-"musclecar" BH, BP & JH)
VS.
383HP 4bbl 335hp - orange engine w/HOLLEY carburetor - STANDARD engine for the E-body musclecar BS & JS (ONLY available in non-"musclecar" BH, BP & JH with manual transmission)
carburetor, cam, valve-springs & windage tray are differences between the 2 engines
Re: 70 383 330hp vs 335hp [Re: 6bblgt] #3018313
02/24/22 12:46 AM
02/24/22 12:46 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My new plane jane 1970 Challenger, 4 speed bucket seats no console, had orange engine and Holly carb with bog city distributor.
Plus my sisters car 1970 Coronet, orange engine and Holly carb auto on the column.
Re: 70 383 330hp vs 335hp [Re: 3hundred] #3018773
02/25/22 10:58 AM
02/25/22 10:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The cams are the major difference. The 383 2bbl and 383 4 bbl have the same cam/valve springs that is used in the 350HP 440, the 335hp 383 has the same cam/valve springs used in the 375 hp 440. Everything else is window dressing.
In 1969 only the 330HP 383 used in the A body is the same 335hp engine used in the Road Runner in Superbee, though it has a dual point distributor along with the restrictive left manifold. Interestingly I believe the 440 in the A body is rated at 375hp despite the restrictive left manifold ????
Re: 70 383 330hp vs 335hp [Re: JohnRR] #3018826
02/25/22 01:56 PM
02/25/22 01:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If I remember right I don’t think the little cam 383 made 330 hp more like 275 advertised a real pig
Re: 70 383 330hp vs 335hp [Re: cudaman1969] #3018994
02/26/22 01:31 AM
02/26/22 01:31 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
67 383 lo po in a 69 RR vert - no power even though it had the hi po manifolds. Was easy on gas.
69 383 numbers engine in 69 rr, sounded rowdy, couldn’t tell much as it was worn out when in car. Changed engines.
69 super bee with worn but serviceable 383 numbers engine. Nice combo, plenty of power though all stock.
70 383 hp put in 69 rr. Was mean with intake and headers with avs. Was wicked feeling with 750 Holley.
Just paint your engine Hemi orange. Nobody wants to see a correct blue or turquoise no matter how correct it is.
I want my fair share
Re: 70 383 330hp vs 335hp [Re: SomeCarGuy] #3019041
02/26/22 10:48 AM
02/26/22 10:48 AM
moparx Offline
moparx  Offline
i like the turquoise color. biggrin
even if it's not the correct color for the engine.
hemi orange is getting like chevy orange, on everything.
just the opinion of a crabby old man mumbling in his cheerios.
your mileage will vary.......
beer
Re: 70 383 330hp vs 335hp [Re: 6bblgt] #3019104
02/26/22 03:50 PM
02/26/22 03:50 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
1970
E-body
VS.
Thanks,
Looking at the 70-71 Chrysler parts book there is no difference in cams based on HP vs Non-HP although they do list a different cam for raised ring. What is that?
